  • Black Friday Sale🔥
    • Seestar Smart Telescopes
  2. Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
$999.00 USD Regular price
USD/per
34 reviews
In Stock & Ready to Ship
Seestar S50 Pro comes with a tripod. For a better EQ Mode experience, we recommend using it with TH10.
  • If you purchase S50 Pro + TH10, you'll receive a FREE 3/8" Screw Quick Release Plate to improve imaging stability.
  • If you already own the TH10 Tripod Head, simply purchase S50 Pro + Quick Release Plate for improved imaging stability in EQ mode.
Seestar S50 Pro Smart Telescope
50mm Aperture. The Universe, Revealed
Pro Performance. Built to Explore.
Five major upgrades. One powerful new Seestar.
50mm aperture 4k view 9 hour battery
Professional-Grade Imaging
All-in-One. Ready for more.
Traditional astrophotography often requires multiple devices—such as a telescope, equatorial mount, and camera—along with complex wiring and setup.
Seestar integrates its core imaging system into one compact device for easy carrying and fast setup. Whether you’re on a family trip or embarking on your next outdoor creative adventure, capture the beauty of the universe whenever inspiration strikes.
Professional-Grade Imaging portable
Just Three Steps
Create Cosmic Shots in Seconds
Three Steps Cosmic Shots
From Deep-sky to Everyday Viewing, Capture It All
Four modes cover the universe and the world around you, bringing every discovery into clear view.
stargazing milky-way solar system scenery mode
50 mm Large Aperture
Sharper Detail. Greater Light-Gathering Power.
With nearly three times the light-gathering area of a 30 mm aperture, the 50 mm aperture delivers faster light collection and greater optical resolving power. Paired with a 4K 1/1.2-inch large-format sensor, it reveals rich detail—from faint structures in deep-sky objects to the intricate textures of the Sun and Moon.
Deep-sky sample images
DSO Mosaic Stitching
Telephoto mosaic capture stitches a wider frame while preserving telephoto detail. It expands the field of view and can output up to 8K high-resolution images.
8K wider frame DSO Mosaic Stitching
Professional-Grade Optical Design
Folded optical path design, compact and portable.
Folded optical design portable
4-Element Apochromatic Lens
The result is a night sky rendered with clarity and balance — true to what the eye expects and the universe deserves.
Triple Filter System
Astronomical light pollution filter reduces interference from moonlight and urban light pollution.
Dark frame filter subtracts noise from long exposures.
IR-cut filter blocks infrared interference for cleaner astrophotography.
4-element apochromatic lens Triple Filter System
4K Dual-Lens
Ultra-Clear Imaging to See Deeper and Capture Wider
Telephoto and wide-angle cameras work together, both supporting 4K UHD resolution.
The telephoto camera features a 1/1.2" large sensor for clearer deep-sky object details.
The wide-angle camera records a broader starfield, keeping the whole scene in frame.
The dual-camera system balances deep-sky capture with wide-field astro shooting.
Telephoto and wide-angle dual cameras
Massive Object Database. One-Tap Smart Stargazing.
Select a target in the app and tap GOTO. Seestar automatically locates, tracks, and captures it, delivering cosmic shots in minutes.
seestar capture more objects
One-Tap Post-Processing. Advanced Editing.
Get a polished result with one tap, or take more control with advanced editing tools including star reduction, star removal, cropping, brightness, contrast, noise reduction, saturation, and more. Refine every detail and bring your imagined shot to life.
one-tap smart enhancement
Pro-Level Milky Way Shots
Captured in One Tap
seestar s50 pro capture milky-way photography
More Freedom to Frame, a Wider View
Starry Sky Mode supports multiple Milky Way stitching options
seestar wider frame view
One-Tap Milky Way Arch, 8K Masterpieces Instantly
One-Tap 8k Milky Way Arch
Freeze the Ground, Two Worlds in Perfect Focus
Intelligently detects and locks the foreground landscape, processing it separately from the sky. Landscape freeze duration can be customized. Stars stay sharp during tracking while the landscape remains clear and natural, creating crisp, striking astro landscapes.
seestar Freeze the Ground
Recognize constellation lines and labels with one tap, then quickly GOTO the target.
Even beginners can easily find their own constellation.
seestar easily find object
Long-exposure star Trail
Sun. Moon. Action.
Seestar makes it easy to capture sunspots, lunar surface details, and rare celestial events such as solar and lunar eclipses. More than a pocket observatory for the night sky, it also serves as a super-telephoto viewing camera for daytime use. From birdwatching and distant landscapes to rocket launches, Seestar is ready to capture it all.
daytime nighttime sun moon surface details
Long Battery Life. Big Storage. Keep Inspiration Going.
Upgraded to a 10,000mAh battery, with up to 9 hours of stargazing.
More peace of mind for all-night observation and more fun for camping under the stars.
10,000mAh battery 9 hours
Plan Mode
Let Seestar Handle Your Night Sky Workflow
Effortless All-Night Shooting
Set it once and leave it to run all night.
All-Night Shooting plan mode
Generate a shooting plan with one tap
Multi-Target Continuous Shooting
Automatically switches targets by plan to capture more celestial objects efficiently.
Continuous Automatical switch with one tap
Equatorial Mode
Offsets the effect of Earth's rotation when tracking celestial targets, enabling stable tracking and longer exposures so objects stay "still" in the frame.
Seestar S50 Pro features a precision drive system with near-zero backlash.    Combined with Equatorial Mode, it delivers faster, smoother tracking and fine adjustments for a significant boost in imaging efficiency.
EQ Mode zero backlash
New Upgraded Tripod. Stability, Leveled Up.
Adjustable Angle
More angle options for more shooting terrain
tripod stable sturdy
AI Assistant
Your Stargazing Friend.
The AI assistant helps with observation, imaging, celestial knowledge, and operation guidance.
Just say the celestial target you want to see. It quickly searches the target, performs GOTO positioning, and starts capture, making stargazing more natural and efficient.
Seestar s50 pro AI assistant
Remote Control
Connect to Your Starry-Sky Device from Anywhere
Keep remote devices under control so weather, location, and time no longer limit your imaging efficiency.
Connect remotely to observe, capture, and organize files with ease. Whether your local sky is cloudy, heavily light-polluted, or in daylight, you can connect to a device in a better observing location and keep creating.
remote control connect from home
Advanced Features. Go Further.
Seestar gives advanced creators more freedom.
Open Expansion
Supports the open ASCOM Alpaca protocol and connects to third-party astronomy software such as N.I.N.A., expanding automated observation and advanced imaging workflows.
From a smart stargazing device to an open astronomy creation platform.
Seestar support ASCOM Alpaca N.I.N.A.
Join the AstroImg
A community of people who love the stars, exploring the sky, creating images, sharing passion, and exchanging inspiration together.
seestar AstroImg community
What's in the box
Model Comparison
FOV
FOV Comparison
Specification
specification of Seestar S50 Pro
FAQ
Q: What can the new wide-angle camera on the S50 Pro do?
A: The S50 Pro features a 4K wide-angle camera with a 63° field of view, enabling:
1. One-Tap Milky Way Arch: Automatically captures and stitches a complete Milky Way arch—no need to manually plan stitching points.
2. Milky Way Time-Lapse: Record the movement of the Milky Way and watch it drift across the night sky.
3. Star Trail Photography: Use long exposures to capture striking circular star trails.
4. 8K Stitching: Create ultra-high-resolution wide-angle panoramas that stay sharp even when enlarged.
5. Wide-Field Live Stacking: Enhance wide-field image quality in real time for cleaner results, faster.
Q: What post-processing upgrades does the S50 Pro offer?
A: The S50 Pro now supports Smart Enhancement and one-tap image processing, including Star Reduction, Star Removal, and Noise Reduction.
Star Reduction makes stars smaller, bringing deep-sky objects such as nebulae and galaxies into clearer focus while preserving a natural star field for a cleaner, more refined image. Set Star Reduction to 100% to enable Star Removal, which removes stars from the image and highlights the textures, contours, and faint details of deep-sky objects. Noise Reduction is automatically applied in Smart Enhancement.
Q: What is the S50 Pro’s one-tap plan mode feature?
A: Based on your target and shooting conditions, Seestar can quickly generate a shooting plan and carry it out automatically. Even if you are unsure what to shoot or how to set the parameters, smart recommendations help you get started with less manual setup and fewer repeated steps.
Q: What can S50 Pro’s Telescope Network feature do?
A: Telescope Network lets you remotely control the S50 Pro for imaging. You can also share or transfer device access, and batch-export photos after a session. Capture and access your images even when the device is not by your side—for a more flexible everyday experience.
Q: How is the S50 Pro tripod different from the S50 tripod?
A: The S50 Pro features a new two-section tripod with two adjustable leg angles. It supports a wider adjustment range, adapts flexibly to different terrain, and provides a more stable shooting experience.
Q: How much internal storage does it have?
A: The S50 Pro has 128 GB of internal storage, with approximately 100 GB available for use.
Q: I already own an S30 Pro. Is it worth upgrading to the S50 Pro?
A: The S30 Pro is a portable all-rounder for a wide range of shooting scenarios. The S50 Pro is built for deep-sky imaging, with a larger aperture, a more capable tracking system, and richer image detail.
If portability and versatile everyday shooting are your priorities, the S30 Pro remains an excellent choice. If you want to capture fainter deep-sky objects and pursue greater imaging detail, the S50 Pro is the better upgrade.
Important Notes
Seestar series products are available in two regional versions: Mainland China and Overseas. The Mainland China version is intended for activation and use exclusively within Mainland China, Hong Kong, and Macau. Activation in other regions is not supported, and products activated outside these designated regions are not eligible for warranty or after-sales service.
Handle with care.
Seestar smart telescope is a precision optical and electronic instrument. Avoid drops, impacts, or strong shocks, which may cause damage.
Image results may vary.
Imaging performance depends on environmental conditions such as light pollution, atmospheric transparency, parameter settings, and stacking duration. Actual results are subject to real‑world shooting conditions.
[1] At 1× magnification, both the telephoto and wide‑angle cameras capture images at 4K (3840 × 2160) resolution. Resolution decreases at 2× and 4× magnification. The real‑time live preview stream for both cameras is 1080P.
[2] Milky Way imaging requires dark‑sky conditions. In areas with significant light pollution, Milky Way details may be limited or not visible. Results depend on on‑site observing conditions.
[3] NFC functionality requires a compatible smartphone. Support varies by device and model—please refer to your phone's specifications.
To use NFC, ensure the telescope is powered on, the phone is unlocked, and Wi‑Fi, Bluetooth, NFC, and GPS are enabled on your phone.
NFC sensitivity varies by device due to antenna placement. Locating your phone's NFC sensing area may improve detection.
If the Wi‑Fi name is changed, NFC information must be updated manually for NFC to work properly.
[4] Due to system usage and storage allocation, available capacity may vary. System updates may affect storage allocation. Please refer to the actual available capacity on your device.
[5] Under ambient temperatures above 25°C, with Alt‑Azimuth Mode and Telephoto Sensor Stargazing Mode enabled, the battery provides up to 9 hours of runtime. Data provided by the ZWO laboratory for reference only. Actual performance may vary.
Data provided by ZWO Laboratory for reference only; actual performance may vary.
[6] 60 s long exposures are supported only in Equatorial Mode and are not available in Alt‑Azimuth Mode. Accurate polar alignment is required in Equatorial Mode to ensure precise tracking. Inaccurate alignment may reduce imaging performance.
[7] A solar filter must be installed when observing the Sun. Never allow the main camera to observe the Sun directly, as this may cause permanent damage to the device.
[8] The Smart Enhancement feature optimizes noise in actual astrophotographic images and enhances the stars captured in those images. It works like beautification applied to existing photos and does not generate AI‑created images. This product is an intelligent astronomical telescope, and all images are authentic captures without AI‑generated content.
[9] Wi‑Fi transmission range is measured under ideal conditions. ZWO Laboratory testing shows a range of up to 10 meters in an open outdoor environment without interference. Actual range depends on real‑world conditions.
[10] Sudden changes such as cloud cover, rain, or strong winds may prevent task completion. The device does not automatically power off in these situations. Please confirm weather conditions before scheduling an imaging plan.
[11] Telescope Network Remote Access is available for a limited‑time free trial during the beta period.
Model Structure
Product Name Seestar S50 Pro
Sensor Size Telephoto: 1/1.2 in   2.9 μm (8.3 MP)
Wide‑Angle: 1/2 in   1.6 μm (8.3 MP)
Sensor Model Telephoto: OmniVision OS08B10
Wide‑angle: IMX586
Resolution Telephoto: 2160×3840 (8.3MP)
Wide‑Angle: 2160×3840 (8.3MP)
Field of View Telephoto: 2.8° (Portrait)
Wide‑Angle: 63° (Portrait)
Aperture Telephoto: 50 mm
Wide‑Angle: 3.4 mm
Focal Ratio Telephoto: f/5.2
Wide‑Angle: f/1.75
Focal Length Telephoto: 260mm
Wide‑Angle: 6mm
Equivalent Focal Length Telephoto: 880mm
Wide‑Angle: 35mm
Working Distance Telephoto: 15 m‑∞;
Wide‑Angle: 0.1 m‑∞
Optical Design 4‑Element Apochromatic Lens (APO), Including ED Glass
Built‑in Filters UV/IR‑Cut Filter (Telephoto + Wide‑Angle)
Dual‑Band Light Pollution Filter: OIII 30 nm / Hα 20 nm (Telephoto Only)
Dark Frame Filter (Telephoto Only)
External Filter Magnetic Solar Filter
Storage Capacity 128 GB eMMC
*Due to the storage chip and system usage, approximately 100 GB of storage is actually available.
Battery Capacity 10,000 mAh; up to 9h of runtime (ZWO laboratory test data)
Power Input Type‑C, Supports DC 5V‑3A; 12V‑3A
Connections Wi‑Fi, USB Type‑C, Bluetooth
Wi‑Fi Reset Supported
Image Format JPEG / FITS
Video Format MP4 / AVI
Wireless Wi‑Fi 5 GHz / 2.4 GHz
Wi‑Fi Range* Up to 10 m
Bluetooth Range* Up to 5 m
Mount Type Alt‑Azimuth; Equatorial Mode Supported
Slew Rate 1×‑1440×
Home Position Mechanical Home Position
Base Port 3/8‑16
Operating Temperature ‑10℃~40℃
Charging Temperature 0℃~40℃
Storage Temperature ‑10℃~60℃
Operating Humidity 20%~80%
Storage Humidity 20%~50%
Weight 2.8kg (Main Unit)
Dimensions 140×149×268mm (Folded)
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
Seestar S50 Pro
$999.00 USD
Based on 34 reviews
68%
(23)
9%
(3)
18%
(6)
6%
(2)
100.0
100.0
D
Dan Frederick
Absolutely love this astrophotography rig for ease of use, quality of build and images, and automation. I'm getting some really quality photos, especially if I do post processing on the computer with AstroWizard and StackingWizard with 2x drizzle and The RC Astro tools. I generally shoot for at least 3 hours of integration time. The only reason I'm keeping it at four stars is due to battery life. I'm in an area where I need the anti-dew setting turned on and with that enabled it most definitely does not shoot all night long. It would be nice if there was a supported extended battery solution that doesn't require you to set a battery pack nearby with a USB cable and hope it doesn't twist around too much and potentially damage the unit. A magnetic breakaway USB cable can help with that. I do recommend using the equatorial mount as well so you're not dealing with rotation of images when you create a plan that runs. Overall though, I'm really happy with this as I'm getting great quality photos and can have the family be involved with this too so we can all enjoy it.
A
Anonymous
I am beyond thrilled. So much to learn!
A
Anonymous
Good unit
J
Jason Gilkey
I have an S-30 Pro and pre ordered the S-50 Pro. The S-50 has had a few malfunctions. On the equatorial mode it would not Polar align. It just went around in circles. After several sessions of turning it of and on it finally started working again. It also sometimes shows distorted images on the Solar System mode. It takes longer to polar align than the S-30. I’m not sure if it was a software bug or something in the unit. Overall, it is not as reliable as the S-30 Pro.
C
Craig Mattice
Amazing quality images. Perfect addition to my S30 Pro. Now I just need warm nights and clear skies. As a 75 year old I never thought I would find something that captures my interest like star gazing with my two Seestars.
