  • Black Friday Sale🔥
    • Seestar Smart Telescopes
  2. On Sale
  3. New AM5N Harmonic Equatorial Mount
  1. Previous
  2. Next
$1,999.00 USD Regular price $2,648.00 USD
USD/per
4 reviews
Astrophotography equipment setup Telescope and mount configuration
Close-up of telescope components
Equipment technical specifications Mount performance chart  Equipment comparison Mount technical details
The load capacity of the AM5N Equatorial Mount is estimated based on the simulation calculations shown above.
1. Maximum reference load without counterweight: 15 kg (maximum output torque: 30 N·m).
2. When the required torque exceeds 30 N·m but remains within 40 N·m: The maximum reference load is 20 kg. A counterweight of ≤ 5 kg is recommended. When using a 5 kg counterweight, set the lever arm to 20–30 cm. The installation position for counterweights of other weights can be calculated as follows:
Assuming the counterweight weighs m kg, the permissible lever arm length L is determined by:
  10 N·m ≤ m × g × L ≤ 15 N·m
Where g = 9.8 m/s², which can be approximated as 10 m/s² for calculation purposes. For example, when using a 2 kg counterweight, the permissible lever arm length L ranges from:
  10 N·m / (2 × 10 m/s²) = 0.5 m to 15 N·m / (2 × 10 m/s²) = 0.75 m.
* The 15 kg and 20 kg values are reference figures, not fixed load limits. Actual load capacity depends on the combined weight of the entire setup, the lever arm lengths, and the overall configuration.
Equipment usage example Technical specifications chart
Product overview image
Product design features Equipment performance details
*Note: The recommended operating voltage for the ZWO Harmonic Equatorial Mount is 12V. When the actual input voltage is below 10.8V, the mount will emit a beeping alarm to indicate under-voltage condition. To ensure proper functioning of the equipment, we recommend using the official ZWO power adapter and an appropriately sized power cable.
Complete product setup
$1,999.00 USD $2,648.00 USD
Based on 4 reviews
100%
(4)
J
Jack
One of the best mounts you should buy without a doubt. The guiding is so good at under .60 arc seconds that I can keep every exposure I take. Also the light weight design of the mount with the carbon fiber tripod makes setting up so much easier. Slewing to targets is very fast, precise, and quiet. One last thing to note is buy it! You won’t be disappointed.
Jack review photo Jack review photo Jack review photo Jack review photo
A
Anonymous
Did my first imaging session last night using the AM5N with the ASIAIR Plus and it was fantastic!!
Anonymous review photo
J
Jason Moore
I like this and have 2 now, as well as no counterweights. A great product and seamless with the Asiair.
F
Faust in Seattle
This mount is worth every penny. Very advanced and easy to use. Light but sturdy. Once I polar aligned I was able to capture long exposures at very high quality and minimal distortions.
