🚀 Holiday Season Sale Is Live — Up to 15% OFF. Shop the Best Deals Now.🎁
  • 🔥Holiday Season Sale
  2. New Arrival
  3. ASI585MC/MM Pro
  1. Previous
  2. Next
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
$539.00 Regular price $599.00
ASI585MM Pro will be shipped approximately 3 working days after placing the order.
ASI585MC/MM Pro Deep Sky Camera
ASI585MC/MM Pro camera with specifications overlay
ASI585MC/MM Pro is a new ZWO deep sky camera based on the 4k SONY CMOS sensor with a 1/1.2″ format and 2.9μm pixels. It has a super high sensitivity and a large resolution of 3840*2160 (8.29MP in total). It also features high transmission speeds – In high-speed mode, the fast frame rate can reach 47fps with low read noise at full resolution! It also features a high SNR and high sensitivity, especially in near-infrared wavelength. Being an entry-level DSO camera, it offers great advantages of high cost-effectiveness.
Note:
External power supplies are needed for all ASl-cooled cameras. We recommend you use a 12V@3A~5A DC adapter (D5.5×2.1mm, center pole positive) or a lithium battery with 11-14V to power the camera. Be aware that using a power supply out of this voltage range will probably lead to irreparable damage to the camera.
ZWO CAA product image
Why Choose ASI585MC/MM Pro?
Comparison chart showing ASI585MC/MM Pro advantages
One Camera for All
STARVIS 2 technology provides advanced imaging performance for both deep-sky objects and solar/lunar/planetary photography thanks to its high frame rate.
ASI585 imaging applications diagram Camera performance specifications
Appreciation Work
Thor's Helmet nebula captured by Dean Linic
Thor's Helmet - Dean Linic
NGC3372 nebula captured by Simon Lewis
NGC3372 - Simon Lewis
Jupiter captured by Jim Rivera
Jupiter - Jim Rivera
Moon surface captured by Christopher Schementi
Moon - Christopher Schementi
Large Full Well Capacity
The back-illuminated structure provides 40ke- full well capacity (3× greater than IMX485 sensors), improving light collection efficiency and preventing highlight overexposure while enhancing signal-to-noise ratio.
Zero Amp Glow Technology
Hardware-level amp glow elimination ensures clean dark frames regardless of exposure length or gain settings.
Dark frame comparison showing zero amp glow
512MB DDR3 Memory
Built-in cache combined with USB 3.0 interface ensures stable high-speed data transmission.
Memory and interface diagram
USB 3.0 Port & USB 2.0 HUB
  • USB 3.0: 5Gb bandwidth enables 47fps at 8.29MP resolution
  • USB 2.0 Hub: Supports accessories like filter wheels and focusers
Camera port configuration
Two-Stage TEC Cooling
Cools sensor to 35°C below ambient (at 30°C), significantly reducing dark current during long exposures.
Note: Cooling performance varies with ambient temperature and duration.
Cooling performance graph Dark current vs temperature chart
Camera Performance
Low Noise with High Dynamic Range
HCG mode automatically activates at gain 200, reducing read noise to 0.7e while maintaining 12bit dynamic range.
ASI585MC Pro
ASI585MM Pro
Quantum Efficiency
Based on our testing results, the QE peak value of ASI585 is 91%.
Quantum efficiency curve Wavelength sensitivity chart
Connection Options (55mm Back Focus)
Camera connection diagram Back focus configuration Optical train diagram
Mechanical Dimensions
Camera dimensional drawing
What's in the Box?
Package contents of ZWO CAA showing all included components
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
ASI585MC/MM Pro
$539.00 $599.00
