  • Black Friday Sale🔥
    • Seestar Smart Telescopes
  2. NEAF 2026 Exclusive Deals
  3. ASI220MM Mini(mono)
  1. Previous
  2. Next
ASI220MM Mini(mono)
ASI220MM Mini(mono)
ASI220MM Mini(mono)
$269.00 USD Regular price $299.00 USD
USD/per
4 reviews
Mechanical Drawing
ASI183 Pro Accessories Set 1 ASI183 Pro Accessories Set 2 ASI183 Pro Accessories Set 3 ASI183 Pro Accessories Set 4 ASI183 Pro Accessories Set 5 ASI183 Pro Accessories Set 6 ASI183 Pro Accessories Set 7 ASI183 Pro Accessories Set 8 ASI183 Pro Accessories Set 9 ASI183 Pro Accessories Set 10
Model ASI220MM Mini
Sensor SC2210
Sensor Size 1/1.8" 7.68×4.32mm
Resolution 1920×1080
ADC 12bit
Read noise 0.6e
FPS 14
QE 92%
USB 2.0
ASI220MM Mini can be regarded as an upgraded ver-
sion of the ASI290MM Mini. It has a bigger sensor
format and larger pixel size with better NIR sensitivity.
ASI290MM Mini ASI220MM Mini
Sensor Type1/2.8 IMX290 Type 1/1.8 SC2210_BW
Diagonal 6.5mm 8.81mm
Resolution 2.1MP 1936 * 1096 2.07MP 1920 * 1080
Pixel size 2.9μm 4μm
Sensor size 5.6mm*3.2mm 7.68mm*4.32mm
Fast fps 20.4fps 14fps
Readout noise 1.0~3.2e 0.6‑3.2e
QE peak 80% 92%
Full well capacity 14.6ke 8.78ke
ADC 12bit 12bit
Protective window φ21‑1.1 AR φ21‑1.1 AR
Back focus distance 8.5mm/12.5mm 8.5mm/12.5mm
Model ASI220MM Mini
Sensor Type 1/1.8 SC2210_BW
Diagonal 8.81mm
Resolution 2.07MP 1920*1080
Pixel size 4μm
Sensor size 7.68mm*4.32mm
Fast fps 14fps
Shutter Rolling Shutter
Exp 32μs~10s
Readout noise 0.6‑3.2e
QE peak 92%
Full well capacity 8.78ke
ADC 12bit
USB port USB 2.0 Type‑C
Adapter 1.25"/ M28.5*0.6
Weight 60g
Usage temperature ‑5℃~50℃
Usage humidity 0‑80%
Operation system WIN7/8/10/11 32&64, Linux, Mac
ASI220MM Mini FPS
USB2.0
12BIT ADC
Resolution RAW16 RAW8
1920*1080 7fps 14fps
1280*720 10.4fps 20.8fps
640*480 15.3fps 30.5fps
320*240 28.7fps 57.4fps
ASI183 Pro Accessories Set 13
ASI220MM Mini(mono)
ASI220MM Mini(mono)
ASI220MM Mini(mono)
$269.00 USD $299.00 USD
Based on 4 reviews
100%
(4)
A
Anonymous
Nice little camera, I love it!
C
Carl Clayton
Excellent service!! Thank you....
A
Anonymous
The camera works very as a guide camera.
J
Jason
Amazing
