  2. Mounts
  3. New AM5N Harmonic Equatorial Mount
  1. Previous
  2. Next
$2,299.00 Regular price $2,648.00
SKU: ZWO AM5N+TC40
4 reviews
Astrophotography equipment setup Telescope and mount configuration
Close-up of telescope components
Equipment technical specifications Mount performance chart  Equipment comparison Mount technical details
It is recommended to use a counterweight of ≤5 kg. When using a 5 kg counterweight, the lever arm should be installed within the range of 20 cm to 30 cm.
For counterweights of other masses, the installation position can be calculated as follows:
Assume the counterweight mass is m kg. The allowable lever arm length L is defined by:
10 N·m ≤ m × g × L ≤ 15 N·m
where g = 9.8 m/s², which can be approximated as 10 m/s².
For example, if a 2 kg counterweight is used, the allowable range of L is from
 10 N·m / (2 × 10 m/s²) = 0.5 m to
 15 N·m / (2 × 10 m/s²) = 0.75 m.
Equipment usage example Technical specifications chart
Product overview image
Product design features Equipment performance details
*Note: The recommended operating voltage for the ZWO Harmonic Equatorial Mount is 12V. When the actual input voltage is below 10.8V, the mount will emit a beeping alarm to indicate under-voltage condition. To ensure proper functioning of the equipment, we recommend using the official ZWO power adapter and an appropriately sized power cable.
Complete product setup
$2,299.00 $2,648.00
Based on 4 reviews
100%
(4)
J
Jack
One of the best mounts you should buy without a doubt. The guiding is so good at under .60 arc seconds that I can keep every exposure I take. Also the light weight design of the mount with the carbon fiber tripod makes setting up so much easier. Slewing to targets is very fast, precise, and quiet. One last thing to note is buy it! You won’t be disappointed.
Jack review photo Jack review photo Jack review photo Jack review photo
A
Anonymous
Did my first imaging session last night using the AM5N with the ASIAIR Plus and it was fantastic!!
Anonymous review photo
J
Jason Moore
I like this and have 2 now, as well as no counterweights. A great product and seamless with the Asiair.
F
Faust in Seattle
This mount is worth every penny. Very advanced and easy to use. Light but sturdy. Once I polar aligned I was able to capture long exposures at very high quality and minimal distortions.
