🚀 Holiday Season Sale Is Live — Up to 15% OFF. Shop the Best Deals Now.🎁
  • 🔥Holiday Season Sale
  2. Mounts
  3. AM3 Harmonic Equatorial Mount
  1. Previous
  2. Next
$1,499.00 Regular price
3 reviews
ZWO ASI Mount product image
ZWO ASI Mount structure diagram
The traditional equatorial mount requires heavy counterweights. It can be very difficult to keep balance in RA and DEC directions, and also inconvenient for transit and storage, which brings amateur astrophotographers a lot of pain when they are out for imaging.
Some of the strain wave geared drive mounts are relatively simple in functions, insufficient in load capacity, and also not very stable in use.
To solve the above issues, ZWO developed the ASI Mount series. No need for a counterweight. With a self-weight of 3.9kg, AM3 has a large load capacity from 8kg to 13kg. While portability is very important, stability is also essential in use. Instead of blindly pursuing the lightweight of the mount body, ZWO is more so along the lines of stability for an entire use. The internal structure of the body is optimized with the strain wave gear reducer and synchronous belt, bringing more accurate control and an amazing reduction ratio of 300:1. It is also multi-functional that can be used as both an equatorial mount or an altazimuth mount. You can either control the mount via Wi-Fi and Bluetooth, or a hand controller.
ZWO ASI Mount functional diagram
Portable and stable
ZWO ASI Mount showing portability and stability
Customized Strain Wave Gear
ZWO developed the special strain wave gear based on the actual needs for astrophotography. It comes with very low periodic error and high torque. Each mount is tested and equipped with an exclusive PE curve before it leaves the factory so that the quality can be guaranteed.
ZWO customized strain wave gear close-up
ZWO strain wave gear mechanism
3.9kg Net Weight
ZWO ASI Mount weight demonstration
8kg-13kg payload
The load capacity of AM3 without the counterweight is 8kg, and 13kg with the counterweight.
ZWO ASI Mount load capacity chart
The load capacity of the AM3 mount, as depicted in the above figure,
Results from simulated calculation:
1. Maximum load without the counterweight: 8kg (maximum output torque: 16N · m);
2.Supported counterweight:≤5kg. Maximum load capacity with the counterweight: 13kg.
The counterweight should be secured on a counterweight bar of no more than 20cm in length.
Equatorial Mode / Altazimuth Mode
Can be switched via ASI Mount App or hand controller
Equatorial Mode: Suitable for tracking and photographing objects
Altazimuth Mode: Suitable for visual astronomy
ZWO ASI Mount mode comparison
All-round 0°-90° Latitude Scale
Gear 1: Allow you to adjust the latitude adjustment knob to achieve a degree between 0 and 60.
Gear 2: You can loosen the hex-head screw and then adjust the latitude adjustment knob to achieve a degree between 30 and 90.
ZWO ASI Mount latitude adjustment scale
Wireless Control
Tonight’s Target, GOTO, Live Preview and so many great functions can all be achieved with your phones.
ZWO ASI Mount wireless control via phone
Rocker-style Hand Controller
Comfortable touch and easy to use. Integrated with Wi-Fi network allowing for wireless control. You can easily upgrade the firmware of the hand controller and mount it on the webpage.
ZWO ASI Mount rocker-style hand controller
Seamless Linkage with ASIAIR
ASIAIR can control AM3 via a wired or wireless connection. The ASI package gives customers the best astrophotography experience.
ZWO ASI Mount connected with ASIAIR
ZWO ASI Mount usage scenario 1ZWO ASI Mount usage scenario 2 ZWO ASI Mount usage scenario 3 ZWO ASI Mount usage scenario 4
*Note: The recommended operating voltage for the ZWO Harmonic Equatorial Mount is 12V. When the actual input voltage is below 10.8V, the mount will emit a beeping alarm to indicate under-voltage condition. To ensure proper functioning of the equipment, we recommend using the official ZWO power adapter and an appropriately sized power cable.
ZWO ASI Mount detailed specification sheet
ZWO ASI Mount user manual
In the Box
ZWO ASI Mount package contents
Accessibility tools
① Pier Extension
With the pier extension, the telescope with a long focal length will be greatly avoided from hitting the tripod legs.
ZWO ASI Mount pier extension accessory
② Carbon Fiber Tripod
  1. Short and portable. Easy to transport inside your hand luggage.
  2. Carbon fiber material: High strength and high impact resistance.
  3. Adjustable height: 470-800mm. Dual-section legs provide a stable and rigid platform for telescopes and cameras.
  4. Spreader plate: Increase the stability of the tripod.
  5. Weight bag: Provides additional stability by filling it with suitable weights such as stones or your telescope battery pack.
  6. Fixed spread angle: Easy to use.
ZWO carbon fiber tripod for ASI MountZWO tripod specifications
ZWO tripod stability features
Based on 3 reviews
100%
(3)
C
Carlos Osorio
Compré esta montura y me encantó, es ligera y he hecho exposiciones largas y funciona de maravilla, tuve la oportunidad de probarla en el hemisferio Sur en cielos de Atacama Chile y funcionó todo muy bien, al igual que con el AsiAir.
G
Gregg
Upgraded from my loaded-to-maximum weight star-tracker to the AM3 and was thrilled with the light weight without counterweights. The carrying case was a bonus. With basic settings recommended by other users before fine-tuning I'm getting ~ 0.5" guiding on my first night. Stellar! (pardon the pun).
C
Charles
Love the weight and accuracy. It is a giant leap in the business of astrophotography.Highly recommended.
