- Unit price
- USD/per
The load capacity of the AM5N Equatorial Mount is estimated based on the simulation calculations shown above.
1. Maximum reference load without counterweight: 15 kg (maximum output torque: 30 N·m).
2. When the required torque exceeds 30 N·m but remains within 40 N·m: The maximum reference load is 20 kg. A counterweight of ≤ 5 kg is recommended. When using a 5 kg counterweight, set the lever arm to 20–30 cm. The installation position for counterweights of other weights can be calculated as follows:
Assuming the counterweight weighs m kg, the permissible lever arm length L is determined by:
10 N·m ≤ m × g × L ≤ 15 N·m
Where g = 9.8 m/s², which can be approximated as 10 m/s² for calculation purposes. For example, when using a 2 kg counterweight, the permissible lever arm length L ranges from:
10 N·m / (2 × 10 m/s²) = 0.5 m to 15 N·m / (2 × 10 m/s²) = 0.75 m.
* The 15 kg and 20 kg values are reference figures, not fixed load limits. Actual load capacity depends on the combined weight of the entire setup, the lever arm lengths, and the overall configuration.
One of the best mounts you should buy without a doubt. The guiding is so good at under .60 arc seconds that I can keep every exposure I take. Also the light weight design of the mount with the carbon fiber tripod makes setting up so much easier. Slewing to targets is very fast, precise, and quiet. One last thing to note is buy it! You won’t be disappointed.
I like this and have 2 now, as well as no counterweights. A great product and seamless with the Asiair.
This mount is worth every penny. Very advanced and easy to use. Light but sturdy. Once I polar aligned I was able to capture long exposures at very high quality and minimal distortions.
