  • Black Friday Sale🔥
    • Seestar Smart Telescopes
  2. Star party/3AP Discount
  3. OIII Filters
  1. Previous
  2. Next
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
$134.00 USD Regular price $149.00 USD
USD/per
1 review
Low inventory notification: Your order may ship approximately 10 days after you place it. Thank you for your understanding.
Narrowband filter does not eliminate the effects of light pollution or increase the object’s brightness. In many cases, they increase the contrast between nebula and night sky, not brightening the nebula.
It can reduce the transmission of certain wavelengths of light, specifically, those produced by artificial light including mercury vapor, and both high and low-pressure sodium vapor lights and the unwanted natural light caused by neutral oxygen emission in our atmosphere (i.e. skyglow).
From 2018, ZWO Made progress on narrowband filters with the new standard, providing better performance.
The ZWO narrowband O-III 7nm filter is designed for nebula observation allowing the 7nm bandwidth of light centered on a wavelength of 500nm through, which corresponds to OIII emission lines, blocking out all other light. Adding the ZWO O-III Narrowband filter to your imaging collection will help you go beyond the RGB imaging and will help capture your favorite nebulas in a new light, no matter how polluted your skies may be!
ZWO New narrowband 1.25″ filter
Technical Parameter
Name: ZWO New narrowband 1.25″ filter
Thickness: 5.5mm+2.5mm(thread)
Glass thickness: 1.85mm
Thread: M28.5*0.6 male thread
ZWO New narrowband O-III 1.25\
ZWO New narrowband 31mm filter
Technical Parameter
Name: ZWO narrowband 31mm filter
Thickness: 2mm
ZWO New narrowband O-III 31mm filter product view
  • Hubble look of images can be made by the combination of H-alpha, OIII-CCD and SII-CCD, such as the famous “Pillars of Creation” (M16 Eagle Nebula)
  • Narrowband imaging with SHO set (H-alpha, OIII-CCD and SII-CCD) can be done with the moon up in heavy light pollution, so your equipment is not sitting dormant for several weeks
  • H-alpha filter is the first narrowband addition to LRGB set for most imagers who blend a black-and-white Ha image into RGB data to enhance structural detail while maintaining natural look
New OIII filter:
Both side will be fine.
ZWO New narrowband 2″ filter
ZWO New narrowband O-III 2\
Technical Parameter
Name: ZWO New narrowband 2″ filter
Thickness: 5mm+2.5mm(thread)
Thread: M48*0.75 male thread
ZWO New narrowband 36mm filter
Technical Parameter
Name: ZWO New narrowband 36mm filter
Thickness: 2mm
ZWO New narrowband O-III 36mm filter product view
New OIII filter:
Technical Data
  • FWHM:7±0.5nm
  • Fine-optically polished to ensure accurate 1/4 wavefront over the both surfaces
  • About 90% transmission at H-alpha line 656nm (H-Alpha filter )
  • About 90% transmission at SII line 672nm (SII filter )
  • About 90% transmission at major OIII line 500nm (OIII filter )
  • Infrared wavelength 700-1100nm cut-off
  • <0.1% transmission of off-band, OD3(Optical Density)
Transmission Curve
ZWO New narrowband O-III filter transmission curve diagram
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
OIII Filters
$134.00 USD $149.00 USD
Based on 1 review
100%
(1)
B
Benson Walker
Works great.
