  2. DSO Cooled Cameras
  3. ASI6200 Pro Series
  1. Previous
  2. Next
ASI6200 MM MC Pro-1
ASI6200 MM MC Pro-2
ASI6200 MM MC Pro-3
ASI6200 MM MC Pro-4
ASI6200 MM MC Pro-5
ASI6200 MM MC Pro-6
ASI6200 MM MC Pro-1
ASI6200 MM MC Pro-2
ASI6200 MM MC Pro-3
ASI6200 MM MC Pro-4
ASI6200 MM MC Pro-5
ASI6200 MM MC Pro-6
ASI6200 Pro Series
$3,999.00 Regular price
SKU: ZWO ASI6200MC-P25
1 review
ASI6200MM/MC Pro Camera
ASI6200MM/MC Pro uses Sony’s back-illuminated IMX455 Full Frame format native 16-bit ADC sensor. It has 3.76µm, ultra-low 0.86e readout noise and an innovative breakthrough resulting in zero amp-glow.
Note:
External power supplies are needed for all ASI-cooled cameras. We recommend you use a 12V@3A~5A DC adapter (D5.5×2.1mm, center pole positive) or a lithium battery with 11-14V to power the camera. Be aware that using a power supply out of this voltage range will probably lead to irreparable damage to the camera.
ASI6200MM Pro Sensor
ASI6200MC Pro Sensor
Six Unmissable Advantages
Appreciation Work
Appreciation Work 1 Appreciation Work 2
Exquisite Craftsmanship for a Premium Imaging Experience
1. Meticulous design, uncompromising quality.
The body weighs just 0.7 kg(1.54 lbs), yet delivers outstanding image performance.
Meticulous design
2. Zero Amp Glow – worry-free imaging even with long exposures and high gain.
The ASI6200MM/MC Pro features a true “zero amp glow” sensor, delivering exceptionally clean dark frames. Even during long exposures or at high gain settings, astrophotographers can easily capture high-quality images.
Zero Amp Glow
3. Anti-dew
ASI6200MC Pro comes with the polyimide heater that can avoid any dew problems.
The anti-dew heater which completely fit the protective window will heat it to avoid any dew problems.
Anti-dew
Extraordinary performance captures the beauty of the universe
1. Full Frame format
The ASI6200 Pro camera uses a full-frame format. The outstanding 9576×6388 resolution provided by the onboard Sony IMX455 sensor makes this camera a 61.2-megapixel full frame powerhouse! The sensor length and width are 36mm x 24mm respectively, and the diagonal is 43.3mm. This is a camera with a small pixel size of 3.76um that can accommodate a large well depth of 51.4ke.
Full Frame format
2. Native 16bit ADC
ASI6200 Pro camera is our first batch of CMOS astronomy cameras with true 16-bit ADC. It is not a CCD-style 16-bit ADC – it really can achieve a dynamic range output of 14 stops. This significantly improves the image sharpness and contrast, and the contrast gradients are smoother and more natural-looking.
Native 16bit ADC
3. Two-stage TEC cooling
Thanks to its two-stage TEC cooling system, the ASI6200 Pro can reduce the CMOS sensor temperature by 30°C–35°C below ambient, significantly lowering dark current and sensor noise even during long exposures.
The ΔT of 35°C is measured at 30℃ ambient temperature.
Practical features for effortless astrophotography
1. USB3.0 & 512M DDR3 Memory
The ASI6200 Pro camera is equipped with a USB 3.0 transmission interface and a built-in 512MB DDR3 cache to ensure stable and secure data transmission.
*ASI Cooled Cameras produced after August 2023 have changed their DDR3 buffer from 256MB to 512MB.
2. Three sets of screws
The sensor is adjusted by three sets of screws, enabling precise calibration. (Each set consists of a push-pull screw pair.)
Camera Performance: Low readout noise, high dynamic range
The ASI6200MM/MC Pro camera has excellent performance with a dynamic range of up to 14 stops that will greatly reduce the issue of overexposed images, and make colour gradients look smoother and more natural-looking.
The innovative design of the ASI6200MM Pro also includes high conversion gain mode (HCG) that automatically kicks in at a gain setting of 100, reducing the amount of read noise while simultaneously preserving the dynamic range during high gain imaging.
Camera Performance
QE value
The QE peak value of the ASI6200MC Pro camera is 80%.
The QE peak value of the ASI6200MM Pro camera is 91%.
Quantum Efficiency(ASI6200MM Pro)
Relative response(ASI6200MC Pro)
Ultra-low dark current
The unique dark current suppression technology can further reduce dark current noise. At a cooling temperature of 0°C, the dark current noise is only 0.0017e/s/pix. This means a 300s exposure will only cause a dark current noise of 0.51 e/pix, which is completely negligible!
ultra-low dark current
Camera Details
Camera Details
Key Specifications
Product Name ASI6200MM P25 ASI6200MC P25
Sensor IMX455 CMOS IMX455 CMOS
Full frame 36×24mm 36×24mm
Resolution 9576×6388 9576×6388
ADC 16bit 16bit
FPS 6.3 6.3
QE 91% 80%
Full well 51.4Ke 51.4Ke
Cooling Temperature 30℃–35℃ 30℃–35℃
Buffer 512MB DDR3 512MB DDR3
Interface USB 3.0 USB 3.0
Read noise 0.86e 0.86e
Pixel Size 3.76μm 3.76μm
Mechanical Diagram
Mechanical Diagram
What‘s in the box?
What‘s in the box?
The standard package includes one long USB cable and two short USB cables, making it convenient for different usage scenarios—for example, using the long cable for computer-based guiding, and the short cables for guiding with ASIAIR or connecting to the EAF.
ASI6200 MM MC Pro-1
ASI6200 MM MC Pro-2
ASI6200 MM MC Pro-3
ASI6200 MM MC Pro-4
ASI6200 MM MC Pro-5
ASI6200 MM MC Pro-6
ASI6200 MM MC Pro-1
ASI6200 Pro Series
$3,999.00
Based on 1 review
100%
(1)
M
Michael Gabriel
I've had the kit (EFW7-2, OAG-L) just over a month. Considering weather, I've only had a few nights with it. Temps just over 32c/90f.
All of the components are working fine out of the box. The camera cooler had to work hard to deal with the hot ambient temperatures. The quality of the images is what you expect for a IMX455.
The entire kit is heavy. It revealed that I should have loosened the focuser tube brake when I installed the EAF on my ZWO FF130 APO. The resistance from the brake and the weight of the train jammed up the focuser on the scope sometime during the hot night...still not 100% sure what happened. It took some time to fix it and it moves smoothly during daytime testing with the focuser brake loosened. Waiting for clear skies.
OAG-L and the reducer, and the market for scopes with a big image circle:
I've not tested with FF130 .70 reducer yet. But its back-focus measurement is from the M48 connection. This defeats the purpose of using M54 or M68 on the OAG-L to give room for the prism and the full-frame sensor. I am cobbling together spacers to be able to attach at 68mm. But the guide camera will need the nose extension back on. Refocusing the guide camera gets to be tiresome. I will know on my next test if the weight of the kit and the weight of the reducer will sag the focuser tube as it has to be racked out much farther after achieving back-focus with the reducer.
Similar to the reducer constraint. There are not many telescopes that have a 55mm+ circle on the market. This limits you if you want to comfortably use the OAG-L.
I can't blame the kit for the availability or robustness of telescopes on the market right now. I will likely remove the OAG-L and go back to guide scope.
