  2. Nikon lens adapter for 2" Filter wheel
$69.00 Regular price
SKU: ZWO EFW2-Nikon
Nikon lens adapter that can be used to connect Nikon lens to 2”EFW.
The thread of the interface is M54*0.75, which means it can only be mounted on 2” EFW, not suitable for 1.25”/31mm/36mm EFW.
ZWO Nikon镜头转接器产品正面视图
ZWO Nikon镜头转接器侧面细节
ZWO Nikon镜头转接器接口特写
Connection Method:
ZWO Nikon镜头转接器连接示意图
Note: The sensor tilt adapter need to be removed before you connect the camera to the 2” EFW.
ZWO 传感器倾斜转接器拆除示例
Detailed instruction:
1. Prepare the ASI camera, Nikon lens adapter, Nikon lens, 2” EFW, screwdriver and hexagon wrench;
ZWO Nikon镜头转接器安装所需工具及配件
2. Use the hexagon wrench coming with the camera to remove the sensor tilt adapter;
ZWO 用内六角扳手拆除传感器倾斜转接器步骤
3. Use the screwdriver to remove the back cover of EFW;
ZWO 用螺丝刀拆除EFW后盖步骤
4. Disassemble the filter wheel carousel (Note: Please do not disassemble or move the central screw of this carousel, otherwise the EFW will be damaged);
ZWO 拆卸滤轮转盘步骤(标注禁止拆卸中心螺丝)
5. Align the four screw holes of EFW with these in the four corners of the camera chip as shown below. Tighten the screws;
ZWO EFW与相机芯片螺丝孔对齐并拧紧步骤
6. Reassemble the EFW;
ZWO 重新组装EFW步骤
7. Mount the Nikon lens adapter on the back cover of EFW;
ZWO 将Nikon镜头转接器安装到EFW后盖步骤
8. Connect the Nikon lens to the adapter.
ZWO 将Nikon镜头连接到转接器步骤
9. All done.
ZWO Nikon镜头转接器安装完成整体效果
Mechanical Drawing:
ZWO Nikon镜头转接器机械结构图
$69.00
