    • Seestar Smart Telescopes
  2. ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
$249.00 USD Regular price
USD/per
SKU: ZWO OAG-L-68
No reviews
ZWO Off-Axis Guider, provides users with an efficient and convenient guiding solution, suitable for various astrophotography scenarios, the ideal choice for astronomy enthusiasts.
Currently available in three models: OAG, OAG-L, OAG-L-68
Specifications
Product Name OAG OAG-L OAG-L-68
Prism Size 8×8mm 12×12mm 12×12mm
Thickness 16.5mm 17.5mm 17.5mm
Effective Aperture 7.4×5mm 11.7×8.3mm 11.7×8.3mm
Sensor Tilt Plate None Built-in M48 Sensor Tilt Plate Built-in M68 Sensor Tilt Plate
Compatible Filter Wheel 1.25" EFW、2" EFW、36mm EFW 2" EFW、36mm EFW ZWO Square Filter Wheel
Recommended Main Camera ASI cameras with APS-C sensor size or smaller ASI cameras with full-frame sensors or smaller ASI461
Recommended Guide Camera ASI Mini Camera ASI Mini Camera ASI Mini Camera
Weight (Net) 181g 265g 277g
Why Choose ZWO OAG?
Excellent Stability
ZWO Off-Axis Guider (OAG/OAG-L/OAG-L-68)is made of aluminum alloy, lightweight and elegant with moderate thickness, and features a set screw to secure the prism column, for firm and stable connection.
High Precision
ZWO Off-Axis Guider can connect both main camera and guide camera simultaneously, eliminating the need for a separate guide scope. It uses part of the light path from the main telescope for guiding, providing higher precision.
ZWO 1.25" Dual-Focuser (Sold Separately)
When using OAG, pair with ZWO HF Dual-Focuser, for easy and precise focusing. The HF focuser is made of aviation-grade aluminum alloy, precision CNC machined, with sandblasted and anodized surface, for a non-slip and durable experience. (OAG-L and OAG-L-68 come with built-in dual-focuser, for stable guiding performance.)
Note: The ZWO HF (Helical Focuser) is designed exclusively for assisting focus adjustment when connecting ZWO mini series cameras to an OAG for guiding.
Connection Method
How to Use
Mechanical Diagram
OAG
HF
OAG-L-68
OAG-L
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
ZWO Off-Axis Guider
$249.00 USD
Be the first to write a review
