- Unit price
- USD/per
It is recommended to use a counterweight of ≤5 kg. When using a 5 kg counterweight, the lever arm should be installed within the range of 20 cm to 30 cm.For counterweights of other masses, the installation position can be calculated as follows:
Assume the counterweight mass is m kg. The allowable lever arm length L is defined by:
10 N·m ≤ m × g × L ≤ 15 N·m
where g = 9.8 m/s², which can be approximated as 10 m/s².
10 N·m / (2 × 10 m/s²) = 0.5 m to
15 N·m / (2 × 10 m/s²) = 0.75 m.
One of the best mounts you should buy without a doubt. The guiding is so good at under .60 arc seconds that I can keep every exposure I take. Also the light weight design of the mount with the carbon fiber tripod makes setting up so much easier. Slewing to targets is very fast, precise, and quiet. One last thing to note is buy it! You won’t be disappointed.
I like this and have 2 now, as well as no counterweights. A great product and seamless with the Asiair.
This mount is worth every penny. Very advanced and easy to use. Light but sturdy. Once I polar aligned I was able to capture long exposures at very high quality and minimal distortions.
