In stock and ready to ship
Seestar S30 Pro
- Unit price
- /per
Note: Seestar series products are available in two regional versions: Mainland China and Overseas. The Mainland China version is intended for activation and use exclusively within Mainland China, Hong Kong, and Macau. Activation in other regions is not supported, and products activated outside these designated regions are not eligible for warranty or after-sales service.
Recognized by Global Media
Pro Performance, Infinite Cosmos
Seestar Smart Telescope
A New Era of Astrophotography
1. Lightweight: Weighs only 1.65 kg.
2. Intelligent: Smart app control with GOTO and automatic tracking — enjoy stargazing anytime, anywhere.
3. Easy to Use: A highly integrated, all-in-one system that combines the telescope, auto focuser, camera, Alt-Az mount, filter Wheel and controller into a single, compact setup. Just power on and start exploring.
Just 3 Steps to Stunning Cosmic Images
4K Dual-Lens
Wide View, See It All
This dual-lens setup combines a 4K wide-angle camera and a telephoto camera, bringing professional-level imaging performance to smart telescopes. Equipped with a large-size high-sensitivity telephoto sensor and a premium wide-angle sensor, its telephoto unit features a 1/1.2-inch photosensitive surface four times larger than the Seestar S30. As a result, the Seestar S30 Pro achieves superior resolution, less image noise, and purer, more natural picture quality.
Four Imaging Modes
Built for Astrophotography
From distant galaxies and glowing nebulae to the Milky Way in motion — from planets overhead to landscapes below — Seestar S30 Pro captures every perspective in 4K Ultra HD.
One-tap Milky Way & Star Trails
The Milky Way drifts across the frame. Star trails trace their quiet paths through time. In time-lapse, the night reveals its vastness, its rhythm, its wonder.
8K Milky Way Stitching — One-Click Mosaic
The Seestar S30 Pro’s built-in Milky Way stitching automatically creates horizontal or vertical mosaics, expanding the field of view far beyond a single frame while preserving ultra-high-resolution detail.
Freeze the Ground
Two Worlds in Perfect Focus
Lock the landscape, let the sky move. Seestar S30 Pro intelligently separates the foreground from the stars, keeping the Milky Way sharp and free of trails while preserving a crisp, natural landscape — all with a single tap.
Read the Stars with One Tap
Seestar S30 Pro instantly identifies and labels constellations in your view, revealing how stars connect into familiar patterns — clearly, naturally, and at a glance.
Looking for your zodiac? With one-tap GOTO, Seestar automatically locks onto your constellation, removing complexity and letting discovery feel effortless—even the first time.
Vast Celestial Targets
Stargazing Simplified
With access to 80,000+ deep-sky objects and 600,000+ stars, simply select a target in the app and the Seestar will automatically locate, track and capture. Get stunning cosmic images in minutes.
One-Tap Post-Processing, Effortless Imaging
With a single tap, Seestar reduces noise while preserving fine celestial detail — delivering clean, natural images with remarkable clarity.
Apply DBE (Dynamic Background Extraction) to balance uneven backgrounds, making your cosmic shots sharper and more detailed.
DSO Mosaic Stitching
Stunning 8K Image
The device shoots continuously following a planned mosaic grid and automatically stitches the images, creating grand, immersive visuals.
Each capture breaks through the limitations of a single frame, delivering stunning, expansive astrophotography.
Plan Mode
Plan it, sleep on it.
Choose your target and schedule in advance. Seestar takes care of the rest—automatically locating, tracking, capturing, and refining the night sky for you.
No need to stay up all night — never miss a spectacular celestial event.
Equatorial Mode
Designed to counter Earth’s rotation, Equatorial Mode keeps celestial targets precisely tracked—so stars remain sharp and deep-sky objects stay steady in frame for longer exposures.
Additional accessories are required.
Daytime Observation
See Far with a Single Device
Seestar S30 Pro isn’t just a palm-sized observatory for the night sky—it’s also a powerful ultra-telephoto camera for daytime use. From birdwatching and distant landscapes to rocket launches, it brings far-away subjects close with ease.
With photo, video, and time-lapse modes, Seestar quickly locks onto your subject and keeps it smoothly tracked—turning long-distance scenes into clear, stable captures.
4-Element Apochromatic Lens
The result is a night sky rendered with clarity and balance — true to what the eye expects, and the universe deserves.
Triple Filters
Tuned for the Night
A built-in three-filter system adapts seamlessly to different observing conditions—so every scene is captured at its best.
-Dark Field Filter
Automatically suppresses long-exposure noise for cleaner deep-sky images.
-UV/IR Cut Filter
Blocks unwanted infrared light, preserving clarity and true color.
-Light Pollution Filter
Optimized for OIII and Hα, it reduces the effects of moonlight and urban glow—revealing emission nebulae with striking contrast and detail.
Active Anti-Dew Control
Built-in anti-dew control gently regulates the lens temperature to prevent condensation during long sessions, even in cold, humid, or rapidly changing conditions.
The optics stay clear and stable—so your imaging run continues uninterrupted, from first exposure to last.
128 GB Built-In Storage
With 128 GB of onboard storage, you can keep capturing without stopping to manage files or clear space.
No interruptions. No lost moments. Just room to explore, capture, and create.
Unlock More Ways to Explore
Remote Control Across Regions
The Sky, Within Reach. Anywhere.
The Telescope Network connects Seestar telescopes around the world into a single, unified network. Simply add your device, and remote control is instantly enabled—across regions and time zones.
Browse celestial catalogs, tap to GoTo and capture targets, and monitor live views and progress in real time.
Even when you’re not on site, you’re still seeing that sky—with your own eyes.
Seestar AI Assistant
Use simple voice commands to enjoy real-time guidance as you explore the night sky.
Open Integration
Built to Expand
Seestar supports the ASCOM Alpaca open protocol, enabling compatibility with a wide range of third-party software, including NINA and more.
From automated observing to fully tailored workflows, Seestar is more than a device. It’s an open platform, designed to grow with your ideas and expand what’s possible under the night sky.
Join the AstroImg
A place where stargazers gather to explore the cosmos, create, share, and inspire.
What's in the box
Unit is compact and easy to use. App works and helps you lock onto things. EQ mode is amazing. Wish the software made it clearer how to get larger more detailed images though. There is a major learning curve to post processing and stacking after getting footage. It will take you a while to figure out how to get the amazing shots you see others taking.
I finally got to take my Seestar out this weekend after the clouds over Seattle cleared up, and I am incredibly impressed.
So far, I am really happy with this little scope. I'm still very much in the learning phase of how to use it properly, but the results speak for themselves. I did hit some connectivity issues at times trying to get it hooked up, but after a bit of patience and trying again, it connects and gets to work.
Once it’s running, this thing is super fun and completely addictive. It is absolutely fascinating to see what’s actually out there in the night sky right from your phone screen. For anyone starting out or wanting an easy way to explore space, overall, I'm highly impressed!
I like the portability.
The app is a little confusing but I will get used to it.
The play in the gears worries me a bit but so far the pictures are good.
Software is versatile and easy to use. Instructions are very clear. This unit has extremely diverse capabilities. Just follow the directions and amaze yourself.
A 30mm aperture is fairly small for the objects with this focal length. I have my fingers crossed on reliability as I've had three asi cameras fail two within 2 years and one at 2.5 years.
