⏳ NEAF 2026 Deals Live Now – Limited Time Only
🔭Price Drop Alert: APO Telescopes Are Now On Sale
    • 🔥Neaf Deals
  • 🔥Neaf Deals
    • 🔥Neaf Deals
  2. Off-Axis Guide for astronomy photograpy
$128.00 Regular price
This item is a deferred, subscription, or recurring purchase. By continuing, I agree to the cancellation policy and authorize you to charge my payment method at the prices, frequency and dates listed on this page until my order is fulfilled or I cancel, if permitted.
1 review
Feature
1. Lightweight, 16.5mm thickness
2. Large prism: 8*8mm
3. Connect the main imaging camera and the guide camera. No guide scope required!
4. Flexible adaption to your camera and telescope, such as M42 and M48.
5. Fully compatible with all ZWO ASI cameras
6. Good stability and rigid connection to the telescope to minimize flexing of the imaging train
ZWO OAG comes with all adapters you will need for imaging and guiding.
  1. OAG body(with 1.25″ holder and 5mm extender and M42 adapter)
  2. M48 adapter for main imaging camera(in the box)
  3. M48-M42 adapter for telescope and flat lens(in the box)
  4. Hexagon wrench and Spacer(in the box)
Mechanical Diagram
Connecting Diagram
Usage Guide
1. Please calculate the correct required distance for your imaging train at first
for example you need to attach 21mm extender to ASI071 to reach a 55mm back focus distance:17.5mm+21mm+16.5mm=55mm
2. Take off the guider prism part and attach the OAG body to the telescope.
3. Insert the prism part into the OAG body
4. Mount the guide camera
5. Screw the T2 or M48 adapter on the imaging camera according to your mount type.
6. Mount the camera on the OAG in the correct position and lock the 3 screws in place.
7. The final setup
Note: please make sure the prism won’t block the imaging area.
Use the guiding screw to adjust the guiding camera’s focus.
You’d better do it in the daytime to make sure the imaging camera and the guiding camera can reach focus at the same position.
In the Box
$128.00
Based on 1 review
100%
(1)
P
Phil Sipes
I was using an off axis guider with cumbersome set screw adjustments for setting the focus and getting bad guiding. The ZWO off axis guider with the helical focuser has made a huge difference. Better focus makes better guiding. I shoot at long focal lengths making a good guider essential.
