🚀 New Arrival: Seestar S50 Pro | Save $100 with Launch Offer ➔
  2. Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
$199.00 Regular price
SKU: ZWO ASI120MINI
ASI120MINI
ASI120MINI astronomy camera
ASI120MINI camera features
Camera Sensor
The ASI120MM Mini camera integrates the AR0130CS 1/3″ sensor (4.8 mm x 3.6 mm). It is a new model in the "mini"-series of cameras from ZWO. This camera has 1280 x 960 pixels with a pixel size of 3.75 μm x 3.75 μm. It provides 12-bit ADC and the QE peak is almost 80%.
Astrophotography Performance
The ASI120 mini-camera offers you very good performance for planetary imaging as well as for guiding. Low read noise, high dynamic range, AR protective window and much more are just some of the key characteristics that set it apart from the competition.
ASI120MINI technical specifications
High QE
ASI120MINI quantum efficiency chart
120Mini VS 120MM-S
Compared with the ASI120MM-S camera, the new 120-Mini has a sleeker design, less weight, and it can reach focus at the same position as an eyepiece.
ASI120MINI vs ASI120MM-S comparison
Mechanical Drawing
In the Box
ASI120MINI package contents
ASI174MINI
ASI174MM Mini camera integrates Sony IMX249 1/1.2″ sensor (11.3 mm x 7.1 mm). It is the first model in the "mini"-series of cameras from ZWO. This camera has 1936 x 1216 pixels with a pixel size of 5.86 μm x 5.86 μm.  It camera provides 12-bit ADC and its QE peak is 77%.
ASI174MINI astronomy camera
ASI174MINI camera features
ASI174MM mini camera offers you very good performance for planetary imaging as well as for guiding. Low read noise, high dynamic range, AR protective window and much more are just some of the key characteristics that set it apart from the competition.
ASI174MINI technical specifications
High QE
ASI174MINI quantum efficiency chart
174Mini vs. 174MM
Compared with the ASI174MM camera, the new 174-Mini has a sleeker design, less weight, and it can reach focus at the same position as an eyepiece.
USB2.0Port & ST4 Port
USB 2.0 Port: Mini camera has one USB2.0 type-C port. Type-C port is very popular in mobile phones, as it doesn't matter which way you connect it (unlike for example type-A or type-B)
#USB-C to USB-A cable is required.
ST4 Port: The camera can be connected directly to the auto-guider port of the mount.
ASI174MINI ports diagram
ASI174MINI connectivity options
Connecting Drawing
ASI174MINI connection diagram
  1. M28.5-CS adapter
  2. CS-C adapter(optional)
  3. 1.25″ extender
  4. 1.25″ filter(optional)
Mechanical Drawing
What is in the box?
ASI174MINI package contents
ASI camera series comparison
ASI120, ASI174 and ASI290 mini camera have very beautiful outlooks, small size, light weight, this is not a big deal.
We should consider much more...
ASI120, ASI174 and ASI290 mini-cameras all have an appealing design, small size, light weight and much more. And while we are very pleased with the looks of our products, of course what matters the most is how well they perform in their intended use...
How to choose a good guide camera?
Many people might mention the size, ability to fit with different types of equipment (guide scopes, OAG etc.), stability and ease-of-use.
We agree. That is why our cameras in the "mini"-series all fulfill these, what we think are, basic characteristics of a good guide camera.
But what are truly the most important traits. Let's face it, when you set up your equipment for a night of imaging, you just want things to work and to see that smooth graph on your guiding software before you start your imaging sequence. In order to do that, there are some things to consider (apart from the points mentioned above):
  • Sensitivity,
  • Precise guiding,
  • Big FOV.
Guide camera selection criteria
High Sensitivity
Sensitivity is the first thing we considered. This is of course a crucial ability when looking for a star to guide on. So, from the beginning, we were set on using monochrome sensors to design our guide cameras. Because monochrome sensors have much higher sensitivity than their colour counterpart. Luckily the ASI120MM Mini, ASI290MM Mini and ASI174MM Mini all have very high QE peak value - about 80%, which can detect more stars in view and shorten the exposure time in guiding.
Each of the cameras have their own strength and depending on what you value in a guide camera, one might be better for you than the others.
Entry Level
ASI120MM Mini entry-level guide camera
ASI120MM Mini is designed for newcomers, it is more affordable than ASI290MM Mini and ASI174MM Mini. You can easily get the well-sampled stars with the help of ASI120MM Mini. It's light, compact and robust. If you are still wondering about which one you should choose as your first guide camera, the ASI120MM Mini is a very good choice.
Precisely Guiding
ASI290MM Mini precise guiding
ASI290MM Mini is designed for precise guiding. The 2.9um pixel size gives you a higher arcsec/pixel than the ASI224 or ASI120 camera. This means that, in the same guide scope, the ASI290MM Mini can detect movement of stars to a higher degree than the other cameras. ASI290MM Mini will improve your guiding precision with around 30% compared to the ASI120MM Mini.
Big FOV
ASI174MM Mini large field of view
ASI174MM Mini is designed for large field-of-view guiding. This is very useful when looking for a star to guide on, using an OAG. When you use an OAG-guider with a Ritchey-Chretien or Schmit-Cassegrain telescope, the hardest part is to find a suitable guide star. ASI174MM Mini has a larger 1/1.2″ sensor which means your FoV is 4 times bigger than that of the ASI120MM Mini.
Smiling Face
ASI Mini camera back panel design
If you squint your eyes, the back of the ASI mini-camera looks like a smiling face (albeit you have to squint quite hard).  On the back you will find a type-C USB port, which is widely used in mobile phones. The ST4-port is used for auto-guiding on mounts. So if you are having one of those observing nights when Murphy's law is by your side, at least you'll have an excellent guide camera (that smiles at you).
Focus like a eyepiece
ASI mini camera can focus at the same position as an eyepiece. This means that you can focus with an eyepiece, and then directly insert the ASI mini camera into 1.25″ holder - focus done!
ASI Mini camera focus adjustment
Work with OAG
The Mini-camera series are well suited for OAG use: They have a much bigger focus range than normal ASI cameras. No more worrying about your guide camera and main camera not being able to find focus at the same time.
ASI Mini camera with OAG
Work with CS adapter and CS lens
ASI Mini camera with CS adapter
Work with 1.25″ extender
ASI Mini camera with 1.25 extender
Model ASI120MM Mini
Sensor AR0130CS
Sensor Size 1/3",4.8×3.6mm
Resolution 1280×960
ADC 12bit
Read noise 4.0e
FPS 35
QE 80%
USB 2.0
Model ASI120MM Mini ASI120MM‑S
Diameter 36mm 62mm
Weight 60g 120g
Interface type Type C Type B
Speed USB 2.0 USB 3.0
Model ASI174Mini
Sensor IMX174
Sensor Size 1/1.2",11.3×7.1mm
Resolution 1936×1216
ADC 12bit
Read noise 3.5e
Full well 32Ke
QE 77%
USB 3.0
FPS 164
Pixel Size 5.86μm
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
Mini Cameras
$199.00
