  2. M54-Tilter
M54-Tilter
M54-Tilter
M54-Tilter
$59.00 Regular price
SKU: ZWO M54-Tilter
The M54 tilter is making sensor tilt adjustment much easier than before by allowing you to do the adjustment on the rear end of the camera. You now can make some adjustments during imaging, instead of taking the camera off from the telescope.
Compatible camera: ASI2600MC Duo, ASI2600MM/MC Pro, ASI6200MM/MC Pro, ASI2400MC Pro.
It also fits 7x50mm EFW.
ZWO M54传感器倾斜调节器产品外观
How to install the M54 tilter?
  1. Use a hex wrench to take off the three M3 cylindrical screws on the adapter.
    ZWO M54倾斜调节器拆卸M3圆柱螺丝步骤
  2. Disassemble the sensor tilt plate from the DSO camera.
    ZWO 从深空相机拆卸传感器倾斜板步骤
  3. Place the base of the M54-Tilter onto the cooled camera. Fix them with six 5*6Phillips flat-head screws.
    ZWO M54倾斜调节器底座与制冷相机固定步骤
  4. Then place the top cover of the M54 tilter onto the camera. Turn over them and fix the base and top cover with three M3 screws. Please do align the screws to the M3 screw holes (as shown in the mechanical drawing below). The angle between each two M3 screws should be 120°.
    ZWO M54倾斜调节器顶盖与底座固定步骤(标注120°螺丝角度)
Connection Methods
ZWO M54倾斜调节器连接方式示例1
ZWO M54倾斜调节器连接方式示例2
ZWO M54倾斜调节器连接方式示例3
ZWO M54倾斜调节器连接方式示例4
ZWO M54倾斜调节器连接方式示例5
ZWO M54倾斜调节器连接方式示例6
ZWO M54倾斜调节器连接方式示例7
ZWO M54倾斜调节器连接方式示例8
Mechanical Diagram
ZWO M54传感器倾斜调节器机械结构图
In the Box
ZWO M54倾斜调节器包装内容物
6*M2.5 countersunk screws * 6
M54 tilter *1
M54-Tilter
M54-Tilter
M54-Tilter
$59.00
