    • Seestar Smart Telescopes
  2. LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
$249.00 USD Regular price
USD/per
SKU: ZWO LRGB36
The ZWO LRGB Filters has good performance in transmission, also it has good coating, good color separation.
1.25" LRGB Filters
Technical Parameter
Thickness: 5.5 mm+2.5 mm(thread)
Thread: M28.5*0.6
the RGB color combine weights will be approximately 1:1:1
  • Fine-optically polished to ensure accurate 1/4 wavefront
  • more than 92% transmission at passband
  • Infrared wavelength 700-1100 nm cut-off
  • Precision off-band blocking
  • Multi-layers anti-reflection coating
  • Small spectral “gap” to minimize effect of light pollution
  • More parfocal – thickness 1.9+/-0.03 mm
Transmission curve:
ZWO 1.25\
2″ LRGB Filters
Technical Parameter
Thickness: 5 mm+2.5mm(thread)
Thread: M48*0.75
Thickness: 1.85mm
ZWO 2\
How to judge the positive and negative?
It is a little bit hard to judge the LRGB filters. Please watch the picture below carefully.
ZWO LRGB Filters positive and negative judgment guide
LRGB 36mm Filters
Technical Parameter
Thickness: 2mm
ZWO 36mm LRGB Filters front view
ZWO 36mm LRGB Filters side view
ZWO 36mm LRGB Filters installation example
ZWO 36mm LRGB Filters package view
Transmission Curve
ZWO 36mm LRGB Filters transmission curve diagram
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
LRGB Filters
$249.00 USD
