  2. EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
$399.00 Regular price
SKU: ZWO EFW-7x2-25
6 reviews
Note:The ZWO EFW-7x2-25 is in limited stock. Your order will be shipped approximately two weeks after placement.
ZWO electronic filter wheels
The Next-Generation ZWO EFW
Refinded Design · Anti Light-Leak Protection · Built for Astrophotography
A re-engineered internal design helps reduce light leakage, while the refined mechanics deliver smoother, more consistent rotation.
The exterior has been subtly streamlined, giving the wheel a cleaner and more cohesive look.
Nothing dramatic. Just better in the ways that matter — so your imaging workflow stays steady, reliable, and quietly improved.
The ZWO Electronic Filter Wheel (EFW) is available in four models, supporting the following filter sizes:
  Ø1.25"/31 mm filters
  Ø36 mm filters
  Ø2" filters
  Ø50 mm square filters
Key Specifications
specifications of EFW filter wheels
Compatibility
Engineered for full compatibility with all ZWO filters for dependable image quality.
Power & Connectivity
Draws only 120 mA at 5 V and runs entirely from a single USB  connection—no external power supply needed.
Connects to your imaging system via the built-in USB-C port using the included USB 2.0 Type-A to Type-C cable.
Software Support
Works seamlessly with ASIAIR, ASIStudio, ASCOM, and the ZWO SDK for flexible control across platforms.
Driver-Free Design
True plug-and-play design with no driver installation required.
For mounted filters, ZWO recommends using standard mounted filters with a 2.5 mm cell thickness. When using third-party mounted filters, if the filter cell outer diameter exceeds the filter wheel counterbore size, only filter cells thicker than 1.5 mm are supported.
Anti Light-Leak Design
In deep-sky imaging, even small amounts of stray light can compromise your final image.
The new ZWO EFW introduces a series of structural refinementsd to eliminate light leakage from all directions
★ Upgraded Sealing Structure
A re-engineered slot-fit chassis provides a tighter mechanical interface between the top and bottom covers, minimizing potential ingress points for stray light.
★ Dual Light-Blocking Protection
Newly added light-blocking pads on both lateral connection points creates additional optical barrier,  helping maintain clean, uniform frames during long integrations.
★ Fully Enclosed Motor Compartment
The motor assembly is now fully sealed, improving both light isolation and environmental resistance for more stable operation over time.
Refined Exterior Design
The new ZWO EFW features a refined laser-engraved finish and cleaner logo detailing, offering improved visual clarity and a more modern, professional look.
Interface Upgrade
The new ZWO EFW replaces the legacy USB Type-B connector with a modern USB-C interface, providing a more robust, reliable connection and simplifying plug-and-play integration with your imaging system.
Lightweight & Rigid
The new ZWO EFW uses a CNC-machined aluminum alloy body for a lighter, more rigid structure.
The internal filter carousel is made from 6061 aluminum alloy, reducing weight while maintaining excellent strength and stability. The result is a compact, durable design engineered for smooth, reliable operation.
Stable & Durable
The new ZWO EFW is equipped with a high-precision stepper motor, ensuring consistent rotation and stable operation across extended imaging sessions.
Automated Filter Switching
The new ZWO EFW features a motorized, bidirectional filter-wheel drive with precise position indexing. When paired with control software such as ASIAIR (sold separately), it enables automatic filter changes during a scheduled imaging session — enabling fully unattended, hands-free astrophotography.
Connection
ZWO EFW-5x1.25-25
ZWO EFW-8x1.25-25
ZWO EFW-5x2-25
ZWO EFW-7x2-25
ZWO EFW-7x36-25
50mm 7 Slots
50mm 7 Slots
Diagram
7x50 structure
What’s in the box?
Category Filter Wheel Slots Effective Thickness Supported Filters Weight
EFW (Ø1.25"/31mm) 8 Slots 20mm 1.25" mounted filters, filter area thickness ≤ 7 mm (see right diagram); Ø31 mm unmounted filters, thickness 1.5–3.5 mm 530g
EFW (Ø1.25"/31mm) 5 Slots (EFW Mini) 20mm 1.25" mounted filters, filter area thickness ≤ 7 mm (see right diagram); Ø31 mm unmounted filters, thickness 1.5–3.5 mm 300g
EFW (Ø2") 7 Slots 20mm 2" mounted filters, filter area thickness ≤ 7 mm; Ø50 mm unmounted filters, thickness 1.5–3.5 mm 720g
EFW (Ø2") 5 Slots 20mm 2" mounted filters, filter area thickness ≤ 7 mm; Ø50 mm unmounted filters, thickness 1.5–3.5 mm 540g
EFW (Ø36mm) 7 Slots 20mm Ø36 mm unmounted filters, thickness 1.9–3.5 mm 515g
EFW (50mm Square) 7 Slots 16mm 50×50×3 mm filters (supported thickness range: 3–4 mm) 1190g
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
EFW Filter Wheels
$399.00
Based on 6 reviews
83%
(5)
17%
(1)
R
Raghuraman R
Excellent addition to my rig for full automation before winter hits. Now I don't have to go out to swap filters during the middle of the session. Having this electronic filter wheel integrated with asi585mc air camera and the CAA. I am now having total control over the rig and I can plan the filter swaps and targets in the asiair app. Seamless integration and smooth motors (whisper quiet) one of the beast feature I enjoy after using the manual filter wheel. I am now ready for the night sky.
Raghuraman R review photo
A
Anonymous
I love ZWO products, they are all excellent!
R
Rimas Stropus
EFW so far is working great. Nice and quiet and rotates without any conflict. Only issue I have is the documentation. I have mostly ZWO back end and it’s not an unorthodox set up and lacked the detailing for reducer/Spacer/CCA/EFW/Camera explanation. Particularly, how to mount my 2600 Duo! It wasn’t in the procedure!!! I mounted the EFW using the supplied screws working from inside the EFW to secure the camera. Lots of confusing and misleading information out there even from ZWO regarding this. It was 100% unclear how to do it!
Rimas Stropus review photo Rimas Stropus review photo Rimas Stropus review photo Rimas Stropus review photo
C
Christopher Rose
Works as it should. Makes a judder noise when it powers up
Christopher Rose review photo Christopher Rose review photo Christopher Rose review photo Christopher Rose review photo Christopher Rose review photo
B
Bill Hubbard
Works so awesome My first wheel, it's quiet, can't even hear it move or feel it. Super nice.
Bill Hubbard review photo
12
