  2. ZWO Sale
  3. 7x50mm Square Filter Wheel
  1. Previous
  2. Next
$539.00 Regular price $599.00
SKU: ZWO EFW-7x50
The 50mm electronic filter wheel is CNC milled from an aircraft-graded aluminum block. Quality guaranteed!
ZWO 50mm electronic filter wheel product front view
Adopting the quality step motors produced by NPM, Japan features very high precision and reliable performance.
Can be rotated in both counterclockwise and clockwise directions for filter selection in use.
ZWO 50mm electronic filter wheel rotation direction demonstration
Power supply method: USB 2.0
Control method: ASCOM and SDK
Driver: Free of driver
Module: 7 positions, 50mm*50mm
Weight: 1kg
ZWO 50mm electronic filter wheel side detail
Also, can be directly connected to the USB 2.0 ports of the ASI cooled cameras.
Requirements for Filters
  1. Square;
  2. 50*50*3mm (Thickness supported: 3~4mm).
Connection Methods
ZWO 50mm electronic filter wheel connection diagram
Mechanical Diagram
ZWO 50mm electronic filter wheel mechanical structure diagram
In the Box
ZWO 50mm electronic filter wheel package contents
  1. EFW
  2. 0x75mm cross screwdriver
  3. 2m USB 2.0 right-angle cable
  4. 0.5m USB 2.0 right-angle cable
  5. 50mm*50mm filter masks (10pcs)
  6. Darkening rings set
  7. M2.5*6 screws (12pcs)
  8. M3*8 screws (6pcs)
  9. M2*4 screws (26pcs*2bags)
$539.00 $599.00
