  2. ZWO Sale
  3. EAFN/EAF Pro Dedicated Accessories
  1. Previous
  2. Next
$8.00 Regular price $9.90
SKU: ZWO EAF-Sensor
2 reviews
Enhance your focusing experience with our dedicated accessories for the ZWO Electronic Automatic Focuser (EAF). All accessories are available for purchase separately.
Available Models:
EAF-BRK-TK
EAF-C8-C925 (for Celestron C8/C9.25)
EAF-C11-C14 (for Celestron C11/C14)
EAF-HC — Hand Controller for EAF
EAF-Sensor — Temperature Sensor for EAF
Coupler Specifications:
Each coupler kit includes two couplers of different inner diameters (4mm and 5mm).
4mm coupler: Compatible with the latest EAFN and EAF Pro models.
5mm coupler: Compatible with the previous-generation EAF.
ZWO EAF-BRK-TK
ZWO EAF for Takahashi Telescope Bracket (TSA-120, FS-60, FSQ-85, FSQ-106)
What's in the box?
Dimensions / Mechanical Diagram
Coupler size: 4mm – 8mm
Coupler size 5mm–8mm
Coupler size: 5mm – 8mm
EAF-C8-C925
EAF-C8-C925
ZWO EAF Bracket for Celestron C8 / C9.25 SCT
Applicable to: EAF-C8-C925, EAF-C11-C14
What's in the box?
Coupler size 5mm–12.8mm
Coupler size: 5mm – 12.8mm
Coupler size 4mm–12.8mm
Coupler size: 4mm – 12.8mm
EAF-C11-C14
ZWO EAF Bracket for Celestron C11 / C14 SCT
Applicable to: EAF-C11-C14
What's in the box?
Connection Method (Celestron SCT Telescopes)
Compatibility Notice:
For some older telescope models, we recommend measuring the focuser knob diameter before purchase to ensure compatibility with the EAF bracket interface.
EAF-HC Electronic Focuser Hand Controller
Designed exclusively for the ZWO Electronic Automatic Focuser (EAF), this handheld controller features an ergonomic design with durable ABS construction, offering a comfortable grip and secure connection.
Equipped with a two-speed control switch, it allows for precise manual focusing—from fine adjustments to rapid focus moves—with ease and accuracy.
The 1.5-meter cable provides flexible usage, and the standard 4-pin 3.5mm audio jack ensures quick and reliable connection, enhancing operational convenience.
The EAF Hand Controller is your essential companion for astrophotography focusing.
EAF-Sensor Temperature Probe
Specifically designed for the ZWO Electronic Automatic Focuser (EAF), this temperature probe accurately monitors subtle changes in ambient temperature. By providing real-time temperature data, it works in tandem with the focuser to ensure your telescope maintains optimal focus under varying thermal conditions.
Connector Diameter: 3.5mm
Cable Length: 100cm
$8.00 $9.90
Based on 2 reviews
100%
(2)
F
Frank Mraz
Very accurate movements
M
Michael Nixon
I use a number of ZWO devices on of which is the EAF and it has transformed my astrophotography sessions with focusing on stars. 1-2-3 easy to use once installed.
