  2. New Arrival
  3. ASI2600MC/MM Air
  1. Previous
  2. Next
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
$1,999.00 Regular price
SKU: ZWO ASI2600MC-Air
3 reviews
ASI2600MC/MM Air astronomy camera
Main Sensor
The main sensor IMX571 features an APS-C format and 26MP total pixels. The size is 23.5mm in width x 15.7mm in height, and the diagonal is 28.3mm. The 3.76um x 3.76um small pixel size accommodates an impressive full depth of 50ke. With the new hardware technology, it is even extended to 73ke.
IMX571 sensor specifications
Guide Sensor
The SC2210 sensor taken from the ASI220MM Mini camera features very high sensitivity. The QE peak value reaches 92% at 500nm. The read noise is as low as 0.6e. As the new generation of guide sensor, it has achieved great results in guiding, proved by hundreds of astrophotographers.
SC2210 guide sensor performance
Appreciation Work
Astrophotography by Antoine Grelin
© Antoine Grelin
Astrophotography by Logan Carpenter
© Logan Carpenter
Astrophotography by Ian Barredo
© Ian Barredo
Enjoy the Beauty of the Night Sky Anywhere
Portable astrophotography setup
Start Your Astrophotography Journey with Great Convenience
The ASI2600MC/MM Air combines guiding, imaging, and smart control into one compact, lightweight device. Say goodbye to complex setups and enjoy a seamless, hassle-free astrophotography experience.
Effortlessly Connect Multiple Devices
4x USB2.0, 3x DC12V 10A, 1x USB Type-C
USB 2.0 ports for your focuser, filter wheel, and mount; DC 12V 10A input/output ports for reliable power; and USB Type-C port for fast file transfers—you can focus on capturing stunning images without worrying about connectivity issues.
Camera connectivity ports
Shoot with Confidence: Ample Storage and Stability
With a massive 256GB eMMC storage, the ASI2600MC Air allows you to capture multiple targets with ease. Rigorously tested with over 300 benchmarks, it ensures system stability. Plus, the USB 2.0 ports support up to 1TB external storage, giving you plenty of room for all your astrophotography needs.
Dive into the Rich Details of the Celestial Targets
In expanded mode, the full well capacity of this camera reaches 73Ke, which is 1.46 times of that of the IMX571 sensor (51ke), making long-exposure shots less prone to overexposure. The large full well capacity and high dynamic range make capturing both light and dark areas with stunning clarity and detail possible. Witness the miracle details and colors of targets like never before!
Dual-Band Wi-Fi for Stable Signal
Experience unparalleled connectivity with our enhanced external dual-band antenna, supporting both 2.4G and 5G frequencies and offering stable and smooth usage within 20 meters.
Cross-Platform Device Control
Except from ASIAIR App, ASI2600MC Air can also wirelessly connect to ZWO's proprietary PC control software, ASIStudio, and also other 3rd-party PC software. 3rd-party software can be controlled through ASCOM extended protocol Alpaca (requires ASCOM Platform version V6.6 or higher).
Bluetooth Connection Supported
Nice and Neat Wiring with AM3/AM5
Get Fully Control of Your Entire Rig at Your Fingertips
With the ASIAIR smart app, you can easily control guiding, imaging, your mount, and electronic focuser—all from your phone. It supports multiple imaging modes, making it easy for even beginners to quickly learn and capture professional-quality images.
Instant Post-Processing and Sharing
Live stack is supported during your imaging session. You may also make adjustments to brightness, contrast and others on the final image. Instantly share your masterpieces on social media platforms and astronomy communities, making your work stand out.
Go Further With ZWO's Self-Developed System
Powered by ZWO's patented technologies, our system ensures stable astrophotography performance. Continuous App OTA updates keep your device up-to-date with the latest features, enhancing your user experience and expanding your capabilities.
Quantum efficiency(QE) -Main sensor
The QE peak value of ASI2600MC Air's main sensor is estimated to be over 80%.
The QE peak value of the ASI2600MM Air's main sensor is approximately 91%.
Quantum efficiency(QE) – Guide sensor
Guide sensor QE chart
Dark Current
Dark current performance
Power Consumption
Power consumption chart
IR-Cut coating for OSC camera
The ASI2600MC Air camera is equipped with a UV-IR Cut filter (infrared cutoff filter) in front of the sensor, which serves as a protective window.
Camera Specification
Camera specifications table
Image Circle Compatibility Reference
Please refer to the diagram below to understand how ASI2600MC/MM Air cameras match with various telescope image circles.
Telescope compatibility diagram
ZWO Air cameras are compatible with telescopes that support APS-C or larger image formats. Note: When using a telescope with an APS-C image circle, you may notice slight distortion in the guide star. If you're looking for more accurate and stable guiding performance, we recommend using a telescope with a full-frame or larger image circle.
Camera details
Camera detailed view
Model ASI2600MC/MM Air
Main Sensor IMX571
Sensor Size APS‑C, 23.5×15.7mm
Resolution 6248×4176
ADC 16bit
FPS 10.8(1920×1080)
QE Color 80% / Mono 91%
Read noise 0.9e‑4.2e
Cooling Temperature -30℃ ~ -35℃
eMMC 256GB
Wi‑Fi Wi‑Fi 5, 2.4Ghz/5Ghz
Full well 50Ke
Pixel Size 3.76μm
Guide Sensor SC2210
Sensor Size 1/1.8", 7.68×4.32mm
Resolution 1920×1080
FPS 8.5 (1920×1080)
QE 0.92
Read noise 0.6e
Product Name Wireless Smart Camera
Dimensions Camera body: Ø90mm, 98mm height Antenna: 94mm long
Weight 775g
Operating Temperature -20℃~50℃
Storage Temperature -20℃~60℃
Operating Humidity 20% ~ 90%
Storage Humidity 30% ~ 70%
RAM 2GB DDR4
Storage Space eMMC 256GB
Wireless Network IEEE 802.11a/b/g/n/ac, 2.4Ghz/5Ghz, effective transmission distance: 20m.
DC Power 12V@3A‑10A input. All three DC ports can be used both as input and output. You can use any one among them as power input, meanwhile the other two can only be used as DC output.
HUB USB 2.0 ‑ HUB *4
OS Windows, Linux, Mac OS
Adapter Ring M54x0.75
Back Focus 12.5mm or 17.5mm
Power Mode DC12V‑3A
Max Power Dissipation 27.6W
Mechanical Diagram
Camera mechanical diagram
What's in the box?
Package contents
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
ASI2600MC/MM Air
$1,999.00
Based on 3 reviews
67%
(2)
33%
(1)
S
Shawn
Good a++
P
Peyton Miller
Haven’t been able to use it. Because I never got my telescope. But it’s cool.
A
Anonymous
good enough
