  2. All Products
  3. ASI585MM/MC Air
  1. Previous
  2. Next
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
$1,299.00 Regular price
SKU: ZWO ASI585MM-Air
1 review
Main sensor
Guide sensor
Start Your Astrophotography Journey with Great Convenience
The ASI585MC/MM Air integrates imaging, guiding, and smart control, featuring ZWO's self-developed "Dual Sensor + ASIAir" integration technology. Say goodbye to complex setups and enjoy a seamless, hassle-free astrophotography experience.
Effortlessly Connect Mutiple Devices
4x USB 2.0, 2x DC12V 10A, 1x USB Type-C
USB 2.0 ports for your focuser, filter wheel, and mount; DC 12V 10A input/output ports for reliable power; USB Type-C port for fast file transfers—you can focus on capturing stunning images without worrying about connectivity issues.
Ample Storage, Explore Without Limits
With 256GB eMMC storage, the ASI585MC/MM Air allows you to capture multiple targets with ease. Rigorously tested with over 300 benchmarks, it ensures system stability. Plus, the USB 2.0 ports support up to 1TB external storage, giving you plenty of room for all your astrophotography needs.
Starvis 2  4K Sensor
Image Sensor Technology Beyond the Human Eye's Sensitivity
Equipped with the upgraded STARVIS 2 image sensor, supporting a higher dynamic range.
With this technology, the sensitivity and signal-to-noise ratio of the ASI585MC/MM Air are greatly enhanced, delivering exceptional image quality.
No Amp Glow
The ASI585MC/MM Air exhibits zero amp glow, which ensures extremely clean dark-field images. No matter how long the exposure and how the gain value, you can easily capture high-quality astrophotographs.
Note: It is implemented directly at the hardware level, it does not require software control.
Dual-Band Wi-Fi for Stable Signal
Experience unparalleled connectivity with our enhanced external dual-band antenna, supporting both 2.4G and 5G frequencies and offering stable and smooth usage within 20 meters.
Cross-Platform Device Control
Except from ASIAIR App, ASI2600MC Air can also wirelessly connect to ZWO’s proprietary PC control software, ASIStudio, and also other 3rd-party PC software. 3rd-party software can be controlled through ASCOM extended protocol Alpaca (requires ASCOM Platform version V6.6 or higher).
(Note: 2.4G has a longer transmission distance but slightly slower speed compared to 5G. The 20-meter range is based on multiple tests of the 2.4G frequency in open areas.)
Get Fully Control of Your Entire Rig at Your Fingertips
Powered by ZWO’s patented technologies, featuring smartphone connectivity and OTA upgrades for a seamless astrophotography experience.
Connect, capture, and upgrade effortlessly — astrophotography made smart and fun.
Instant Post-Processing and Sharing
Live stack is supported during your imaging session. You may also make adjustments to brightness, contrast and others on the final image. Instantly share your masterpieces on social media platforms and astronomy communities, making your work stand out.
Efficient Cooling, Superior Image Quality
The two-stage TEC cooling system lowers the CMOS sensor temperature by 30°C–35°C below ambient, effectively reducing dark current generation.
Even during long exposures of several hundred seconds, noise remains minimal.
Note: The lower the ambient temperature, the smaller the cooling differential.
*Based on tests at 30°C ambient temperature. Cooling efficiency decreases as ambient temperature drops, and operation below –20°C is not recommended.
Low Read Noise, High Dynamic Range
The camera has a built-in HCG mode, which can effectively reduce readoutnoise at high gain and allow the camera to maintain the same high dynamicrange as it does at low gain. When the gain is 200, the HCG mode isautomatically turned on and the Dynamic range reaches a level close to 12bit.The readout noise is as low as 0.7e.
ASI585MC Air
ASI585MM Air
QE
After "ZWO Laboratory" calculation, the peak quantum efficiency of ASI585MC Air is 88%. The peak quantum efficiency of ASI585MM Air is 91%.
*Data source: This data is from ZWO Laboratory. The actual quantum efficiency peak value is subject to real-world data.
ASI585MC Air
ASI585MM Air
Dark Current
Power Consumption
Built-in Filters
The ASI585MC Air camera features a UV-IR Cut filter in front of the sensor, serving as a protective window that blocks infrared light.
The ASI585MM Air camera is equipped with an AR (Anti-Reflective) coated protective window, which enhances light transmission and minimizes reflections.
Frame Rate
Camera Specification
Image Circle Compatibility Reference
Please refer to the diagram below to understand how ASI585MC/MM Air cameras match with various telescope image circles.
ZWO Air cameras are compatible with telescopes that support APS-C or larger image formats.
Note: When using a telescope with an APS-C image circle, you may notice slight distortion in the guide star. If you’re looking for more accurate and stable guiding performance, we recommend using a telescope with a full-frame or larger image circle.
Camera Details
Connecting Diagram
Model ASI585MC/MM Air
Main Sensor IMX585
Sensor Size 1/1.2", 11.2×6.3mm
Resolution 3840×2160
ADC 12bit
FPS 10.8(1920×1080)
QE <91%
Read noise 0.7e-
Cooling Tempe 30℃‑35℃
eMMC 256GB
Wi‑Fi 5 2.4Ghz/5Ghz
Full well Color:40Ke, Mono:38.7Ke
Pixel Size 2.9μm
Guide sensor SC2210
Sensor Size 1/1.8", 7.68×4.32mm
Resolution 1920×1080
FPS 8.5 (1920×1080)
QE 92%
Read noise 0.6e
Guide Sensor SC2210
FPS 8.5 (1920×1080)
QE 92%
Read noise 0.6e
ASI585MC/MM Air Frame Rate
Frame rate (IMX585)
Frame rate (SC2210)
Resolution RAW8 Resolution RAW8
1920 × 1080 10.8fps 1920 × 1080 8.5fps
1280 × 960 17.2fps 1280 × 960 8.5fps
1280 × 720 22.2fps 1280 × 720 8.5fps
640 × 480 30fps 640 × 480 8.5fps
480 × 360 30fps 480 × 360 8.5fps
320 × 240 30fps \ \
Item Specification
Storage & Memory 256G eMMC storage, 2GB DDR memory
Wireless 5G/2.4G Dual‑band Wi‑Fi / Bluetooth
Feature Intelligent live stacking
Camera Type 3 in 1 Camera: Imaging, Guiding, Control System
Resolution 4K Resolution
Interfaces USB 2.0 *4, DC 12V 10A *2, USB Type‑C *1
Performance High Signal‑to‑Noise Ratio, High SensitivityRead Speed: 138MB/sWrite Speed: 112MB/s
Sensor Tech STARVIS 2 Technology
Extra Functions Voice broadcast, Unmanned operation
Product Name Wireless Smart Camera
Dimensions Camera body: Ø78mm, 108mm heightAntenna: 94mm long
Weight 620g
Operating Temperature -20℃~50℃
Storage Temperature -20℃~60℃
Operating Humidity 20% ~ 90%
Storage Humidity 30% ~ 70%
RAM 2GB DDR4
Storage Space eMMC 256GB
Wireless Network IEEE 802.11a/b/g/n/ac,2.4Ghz/5Ghz, effective transmission distance: 20m.
DC Power 12V@3A‑10A input. All the DC ports can be used both as input and output.You can use any one among them as power input.
HUB USB 2.0 ‑ HUB *4
OS Windows,Linux,Mac OS
Adapter Ring M42×0.75
Back Focus 12.5mm or 17.5mm
Power Mode DC12V‑3A (whole unit)
Max Power Dissipation 24.6W(whole unit)
Characteristic Main Sensor Guide Sensor
Sensor SONY IMX585 SC2210_BW
Color Color/Mono Mono
Sensor Size 1/1.2" 1/1.8"
Pixel Size 2.9μm 4μm
Shutter Rolling shutter Rolling shutter
Image Resolution 3840×2160 2.07MP 1920×1080
Spectrum Range 200nm‑1000nm 300nm‑1000nm
Read Noise Color: 0.7‑6.67 e
Mono: 0.7‑6.4 e
0.6‑3.2 e (1e@10.6db gain)
Peak Quantum Efficiency <91% 92% at 500nm
Full Well Capacity Color: 40KeMono: 38.7Ke 8.78Ke
Diagonal 13.2mm 8.81mm
Max Frame Rate 10.8fps (1920×240) 8.5fps (1920×1080)
SNR Color:12.7 stopsMono:12.6 stops 11.4 stops
Dynamic Range 12bit 11.43bit
Data/Control
ADC 12bit 12bit
BinADC 10bit \
HSpeedADc \ \
Acquisition Mode Continuous operation, software triggered Continuous operation, software triggered
Analog Gain 0dB‑450dB 0dB‑350dB
Digital Gain 450dB‑600dB 351dB‑600dB
UnityGain 198 68
HCGGain 252 106
Exposure Time 32μs‑2000s 32μs‑2000s
Exposure Control Auto/Manual Auto/Manual
Data Format Color: RAW8, RAW16, RGB24Mono: Mono8, Mono16 RAW8, RAW16, Mono8, Mono16
White Balance Auto/Manual Auto/Manual
Output Format Raw Raw
Software Bin Bin2 Bin3 Bin4 Bin1 Bin2
Offset (recommend) 15 \
Function
Delta‑T 30℃‑35℃ (tested at the environment temperature of 30℃) \
Power Of Heating Tube 2.4W \
Mechanical Diagram
What’s in the box?
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
ASI585MM/MC Air
$1,299.00
Based on 1 review
100%
(1)
S
Sergiy Romanenko
Excellent camera!
