ASI Planet Camera Guide
We have all seen incredible images of the planets online and in books and wanted to see them for ourselves. With ZWO, you can see the rings of Saturn and the great red spot on Jupiter.
ZWO is committed to providing high-quality astronomical cameras at an affordable price to enthusiasts around the world.
The gear you need specifically to start guiding is,
1. Deep space camera
2. Acquisition software/hardware – ZWO ASIAIR
3. Filter Wheel and Filters (optional)
4. Electronic Focus (optional)
5. Guide scope/Off-Axis Guider
6. Guide Camera
ASI Planetary Camera
Retail Price – 179 USD
CMOS AR0130CS
Resolution – 1280x960
Pixel Size – 3.75μm
Imaging the moon is how most get started in astrophotography. If you are a beginner, you cannot go wrong with the ASI120MC-S. This is the best entry-level camera for lunar and planetary imaging. The ASI120 conquered the CCD camera as the go-to for imaging our solar system. Due to its high sensitivity, high frame rate and ease of use, the ASI120 is the perfect choice for planetary photography.
The ASI120-S series has two models the ASI120MM is black and white, more sensitive and requires different filters to make a colour image and the ASI120MC is a colour camera which is easier to use however slightly less sensitive. Both will yield amazing results!
Planetary photography is different from lunar in that the planets are much smaller. This means a longer focal length and or barlow lens is an advantage.
Retail Price – 249 USD
CMOS IMX224
Resolution – 1304x976
Pixel Size – 3.75μm
The ASI224MC is a more advanced choice for planetary photography. It is just as easy to use as the ASI120MC however with a more sensitive sensor and less noise, the results are out of this world (pun intended). It is because of this low noise and sensitivity that the ASI224MC is one of the most popular planetary cameras in the world.
Retail Price – 369 USD
CMOS IMX385
Resolution – 1936x1096
Pixel Size – 3.75μm
The ASI385MC is an upgrade from the ASI224MC. With an ultra-low readout noise of 0.7e and an increased resolution of 1936x1096 pixels, it is the most powerful colour planetary camera.
CMOS IMX290
Pixel Size – 2.9μm
If you want to go further in improving the details of your planetary imaging, you should consider the ASI290MM. This is a black and white camera and with the use of filters, will produce some of the best planetary images you have ever seen!
With an image resolution of 1936x1096 pixels, a low readout noise of 1e and a maximum frame rate of 170FPS at full resolution, the ASI290MM is more than capable of meeting your planetary imaging needs.
This image of Jupiter was taken by Damian Peach with an ASI290MM from France.
Retail Price – 299 USD
CMOS IMX178
Resolution – 3096x2080
Pixel Size – 2.4μm
For higher resolution planetary imaging, the ASI178 is the answer. With a 6.4 megapixel back-illuminated CMOS sensor and a resolution of 3096x2080 and 2.4um small pixels, the ASI178 has amazing sampling accuracy. To improve the quality even further, you can again choose the black and white option.
The ASI178 has been regarded as one of the best cameras for high-resolution imaging.
Retail Price – 599 USD
CMOS IMX174
Resolution – 1936x1216
Pixel Size – 5.86μm
The ASI174MM is recognized as the best camera for solar imaging. It features a 1/1.2" large sensor, a high frame rate of 164fps, and uses the global shutter. It is also a great camera for imaging high-speed moving objects such as ISS.
Accessories
The electronic filter wheel mini supports up to five filters and will change automatically depending on how you have set up your sequence in your imaging software.
The manual filter wheel will also support up to five filters, but you instead switch filters manually.
Atmospheric Chromatic Aberration Correction Mirror (ADC)
ADC is very useful for observing and photographing planets at low angels or during bad seeing. It helps you and your camera see through the turbulence of the atmosphere to produce a clearer image of the planet.
