Maybe you have only one ASI Camera, but Martin has 4. Let's see how does he use these 4 cameras. Source: Astronomy & Sky website of Martin Lewis - Imaging Cameras
My workhorse planetary digital video cameras for several years were DMK monochrome cameras from The Imaging Source,TIS; most recently these were based on the highly-sensitive 640x480 pixel Sony ICX618 CCD chip. Many of the earlier images on this site were taken with these DMK cameras. Times move on though and I sold the last of my DMK cameras in Spring of 2015 to help fund a move to owning a set of four ZWO, CMOS-based, digital video cameras.
I have found these ZWO cameras to be great planetary imaging cameras due to their ease of use, lower noise, higher speed, larger chip sizes and also the ability to select reduced areas of the chip to image with (so-called ROI operation). The customer and technical support for ZWO cameras is also much superior to that from TIS. ZWO is run by amateur astronomers who understand the needs of their customers and is highly innovative, improving their products and adding new products all the time.
I currently own the monochrome and one-shot colour (OSC) version of the ASI120 as well as monochrome and OSC versions of the ASI174.
Row of parfocal ZWO cameras eager to serve! L to R; ASI174MM and ASI174MC (both with low-profile nose pieces), ASI120MM, ASI120MC/S
ASI120MM (mono) and ASI120MC (colour)
The ASI120MM is a 1.2M pixel USB2.0 monochrome, digital video camera with a 1280 x 960 CMOS chip. The one-shot colour version, the ASI120MC/S, uses a similar CMOS chip but with a bayer colour filter matrix over the front. The S suffix means it a USB3.0 camera, capable of potentially higher speeds than the mono camera. The mono has a clear glass protection filter with a wider bandpass than the one-shot-colour camera- the latter incorporates a UV/IR blocking filter. For both cameras the pixel size is 3.75um square, quite a bit smaller than the 5.6um of the DMK cameras I was using previously, and increasing the image scale by 50%. These ZWO cameras are superb performers, great value for money and when Firecapture is used to drive them they are incredibly versatile. They have the following advantages over my earlier CCD based cameras;- Larger chip size allowing easier homing-in on subjects and larger frame sizes for large objects (moon). It also allows me to increase the image scale to make planets larger than 480 pixels across
- Easy to set a reduced frame size (ROI) and get benefits of increased data transfer rates (fps) as well as reduced file size
- Much faster frame transfer rates when not limited by the exposure duration
- Significantly lower noise levels
- Higher sensitivity in the Green and Blue
- ASI camera- any of the four I have
- 1.25" adaptor with compression ring to hold 1.25" camera nosepiece
- Custom modified filter-block to take 1.25" filters on custom holders. Slot-in filters are generally not used for OSC camera but is always kept in the imaging chain for simplicity. The block is used primarily for quick and easy filter changing for the mono ASI120MM camera for Type IIC Astronomiks RGB filters for colour imaging, without needing disturbing the set-up. I can also use an L filter, IR filter or Venus (UV) filter in here for more specialised imaging with the mono camera.
- Atmospheric Dispersion Corrector. See my ADC page for more details. This is left in place again for simplicity and to keep everything parfocal even if the levers are set parallel to nullify its effect.
- Single or doubled APM 2.7x coma correcting barlow elements as desired, giving 2.7x or 5.9x magnification. For best coma correcting performance the distances to the focal plane and the separation need to be at a specific distances. See the table in the section below for the different image scales I can get with my two Newtonian imaging scopes with the two different barlow configurations.
Imaging chain as described above with a pair of 2.7x APM barlow elements to give 5.9x magnification
As above but with single 2.7x APM barlow element at front (and different spacing to focal plane)
Often I use the OSC camera to help set up the ADC and then also capture with it and follow this with mono RGB imaging. Working like this the ADC is still usually correctly set for the mono camera as the focal position is unchanged when swapping the two cameras over. I can also use the cameras in combination for planetary imaging, such as using the red channel from the mono camera to replace the red channel from the colour camera or using the mono to capture a luminance channel to overlay on a colour image. They are a really versatile pairing when used like this.
These days I find that I am using the colour camera more and more in preference to the mono camera for planetary imaging. In the old days planetary imagers often turned their noses up at one-shot colour (OSC) cameras as their performance was often much inferior when compared to using a monochrome imaging with RGB filters. These days the quality of the colour bayer matrix in has improved to the point that when used with an ADC the colour camera's performance approaches that of the mono camera. The mono camera always has the potential to produce the highest resolution images- I never got a red from the colour camera as good as the red from the mono camera (see my Jupiter from18th Feb 2014 for example) but the colour camera is much easier to use and in variable seeing, where the optimum focus changes all the time, is more likely to yield successful high quality final images. When you have a good colour video all three colours are 'in the bag' whereas for mono you have to hope the other two colour channels are good too- which often they aren't. In addition, the colour camera is more productive. 10 colour videos produces 10 reds, 10 greens and 10 blues, whereas to capture this many of each colour with the mono camera would require 30 videos in total to be recorded.
Although the processing is much easier and quicker with the colour camera, each image is generally noisier, due to the lower light throughput and higher gain needed. As a result more images need to be stacked to reduce noise. Usually this is a matter of needing to stack 3 images rather than 2 images cerainly not 3x as many. With a colour camera it is important to keep the image scale up to ensure you have sufficient sampling of the image; although Autostakkert debayering claims to overcome this issue when it is used for debayering.
To get the best performance the colour camera needs to be used with an ADC if you want to get images approaching those of the mono camera (more on this on my ADC page). According to Chris Garry, author of Pipp (Planetary Imaging PreProcessing Program), if you want to use some of
these more modern debayer algorithms (not nearest neighbour) then it is essential that the three colour channels are aligned by use of an atmospheric dispersion corrector beforehand.
I also use my ASI120 cameras at the heart of my home-built All-Sky camera which you can read more about here.
mode) to increase frame rate and reduce file size. They are inherently faster and more sensitive than the ASI120s (both are USB3.0) and do not suffer from the 'fixed pattern noise' issue, where you sometime get a vertically banded pattern of noise at high gain and high camera temperature for the ASI120's. Another advantage of the 174 chip is that it has a global shutter rather than a rolling shutter which will be very useful for my attempts at ISS imaging (rolling shutter causes distortions to the shape of the ISS). ZWO have produced a nice information sheet on these cameras which you can see here.
The ASI174 cameras are supplied with front 2" nosepieces which are 5mm longer than the ASI120s and a different arrangement for the protection window which make it easier to remove to clean the chip. In order to have four parfocal cameras I have removed the longer nosepieces and replaced them with low-profile nosepieces, like those on the ASI120s, where the front of the camera is 12.5mm from the chip (CS-mount distance) rather than 17.5mm (C-mount). This means that I can swap freely between any of the four ZWO cameras without the need to refocus or change ADC settings. The low-profile nose piece does not have a protection window but I have short 1.25" adaptors with appropriate filters on the ends to keep the dust out. Another advantage of the low-profile nosepiece is the ability to use the cameras with my CS-mount fisheye lenses to try them as large area all-sky cameras.
Mounted in the same optical train as described above with one or two 2.7x barlow elements I get a larger image scale (smaller arcsecs/pixel) than with the smaller pixelled ASI120s. With the two different camera pairs and two different APM 2.7x barlow arrangements I actually get four different image scales which allows great flexibility to select my image scale appropriate for the object I am imaging. These different image scales are shown with other key camera details in the table below.
ASI174MM (mono) and ASI174MC (colour)
The ASI1174MM/ASI174MC cameras are a pair of ZWO 2.3M pixel monochrome/colour cameras which use the 5.86um pixel Sony 174 chip which has an amazing quantum efficiency of 80%. With their larger chips, these cameras were originally aimed at the solar and lunar imagers. It turns out, however, that they are also excellent planetary imaging cameras when used with a reduced chip area (so-called ROI
DSLR Camera
This is my Canon 500D DSLR that I got as a birthday present early in 2011 and which I have started using for astrophotography. The camera is unmodded (IR filter not removed) as I use it for daytime photography too. I currently use the image-stabilised Canon kit lenses that I got with the camera which are 18-55mm and 55-250mm focal lengths. These lenses give surprisingly good results given their low cost.
The camera on its modified Manfrotto tripod can be readily mounted on my equatorial platform for tracked shots such as those seen here. Further information on the equatorial platform including a picture of the tripod on the platform can be seenhere.
I can use an Astronomiks CLS (city light suppression) clip filter to reduce the effects of light pollution when using the DSLR. The clip filter sits in front of the flip mirror but with this in place the EFS lenses cannot be used as they foul the filter. I have the following lenses that can be used when the clip filter is in place;
- 50mm f1.4 Super Takumar manual lens, M42 mount with adaptor
- 28mm f2.5 Vivitar manual, M42 mount with adaptor
- 75-300mm Canon EF II zoom
