EAF Software Configuration
ASCOM Installation
The latest version of ASICAP has native support for the EAF. Other software packages will require the use of an ASCOM driver. EAF ASCOM drivers can be found on the ZWO website: https://astronomy-imaging-camera.com/software-drivers ZWO ASCOM driver Download and install support for EAF, then launch the EAF dashboard from within your astronomy software. ZWO ASCOM driver-EAF Introduction of ASCOM driver interface ZWO_ASCOM_driver Note: If you do not have EAF temperature sensor, you can use the inner temperature sensor to detect.
Connecting EAF to your Astronomy Software
There are many kinds of imaging software. We have listed the setting steps of EAF in the mainstream software, so that you can set the EAF in the software more quickly.
ASICAP
1.Open the focuser control panel. ASICAMP_setting_12. choose the focuser that you connected. ASICAMP_setting_23. Set suitable settings for your EAF. ASICAMP_setting_3
ASIAIR
1. On the ASIAIR main screen find the icon for the EAF. ASIAIR_EAF_setting_12. Click the icon and enter the EAF settings page. ASIAIR_EAF_setting_23.EAF Advanced Settings. ASIAIR_EAF_setting_3
Sharpcap
1.Open Sharpcap settings. Sharpcap_EAF_setting_1 2.Choose ZWO focuser. Sharpcap_EAF_setting_2
FireCapture
1.Open the focuser panel in settings menu. FireCapture_EAF_setting_1 2.Check ”Use ASCOM Focuser” FireCapture_EAF_setting_23. Choose ZWO Focuser in ASCOM panel. FireCapture_EAF_setting_3
Sequence Generator Pro
SequenceGeneratorPro_EAF_setting
Maxim DL Pro
1. Open “Observatory panel”, in “Focuser 1” option, click “Choose…”. MaximDLPro_EAF_setting-12. Choose ZWO Focuser in ASCOM panel. MaximDLPro_EAF_setting-2
The SkyX
1.Open “Telescope” menu, and select “Telescope Setup” SkyX_EAF_setting_1 2.Select “Focuser Setup” SkyX_EAF_setting_23. select ASCOM Focuser SkyX_EAF_setting_34. Setup the settings of ASCOM focuser. SkyX_EAF_setting_4 5.Choose ZWO Focuser SkyX_EAF_setting_5 Additional Installation Information There is significant torque from the EAF stepper motor. We recommended setting the 0 position and the maximum number of steps as a first step to prevent possible damage to the focuser. For the standard bracket installation: The 0 position is recommended to be set to the position when the focuser is fully retracted. The maximum number of steps is recommended to be set to a limit position less than or equal to the full focuser stroke. For the curved saddle installation: The 0 position is recommended to be set near the focus of the focus of the focus holder. The maximum number of steps is recommended to be set to a limit position less than or equal to the focus seat stroke. It has to be powered by 12V DC 0.5A and up.
前の投稿 次の投稿
コメントを残す
コメントは公開する前に承認されなければなりません
