[ASIAIR] How to quickly stack and process your data on your phone?
For a long period of time, astrophotographers have to face the dilemma between spending a long time flattening the steep learning curve of astrophotography and just giving up to let go. The software too complicated to start with, the tedious imaging settings and post processing and so many other problems are what astrophotographers deal with each time when they are involved in a new astrophotography project.
Yet all the processes can get simplified by ASIAIR. You may know ASIAIR as a good image tool before – it can do polar alignment, plate solve, focusing, autoguiding, GOTO, autorun and other features with ease. However, ASIAIR can actually do much more than above now. With the new version 2.0, you can stack your planetary and deep-sky targets and quickly process them on your phone – bye bye laptop!
Here we’d like to introduce you how to use the stack function of ASIAIR.
As always, connect your phone to the ASIAIR WiFi and then launch the ASIAIR APP. If you take a closer look, you’ll notice that the v2.0 interface has changed a lot. The UI design and layout have been easier for users to understand and much more friendly for night work.
ASIAIR 2.0 Interface
Go , you may see and on this page. Let’s talk about the DSO Stacking first. This feature is different from the live stack that we used to know. Live stack is for you to stack the DSO data while capturing, while the DSO Stacking here is for you to stack and simply process the data after you complete the data acquisition.
File Manager - ASIAIR
Choose the files you’re going to stack. The stacking process will be automatically done once you click .
Choose the DSO target to stack
You will see how many frames were stacked successfully and how many are failed from the pop-up window.
finish stacking for DSO targets
The stacked fits files can be viewed, shared as a JPG to the ASIAIR community, and also edited if you want to further improve the image quality.
The DSO image stacked
The adjustable options include histogram, brightness, contrast, saturation and Bin mode.
You can also crop the image or mirror, rotate it as you wish.
DSO stacking - image edit
The whole stacking and processing progress is very quick and easy. Of course, if you want to do some more advanced post-processing work for your image, you may still choose Photoshop or PixInsight, but ASIAIR offers a much easier choice for all astronomy amateurs, especially the new beginners. You can produce a good enough astrophoto in minutes, instead of sitting before the computer for hours with a deep frown on your face.
Below is the NGC6992 before and after stack.
Before and after stack
Apart from DSO stacking, ASIAIR can also do planetary stacking. You can stack and sharpen the Sun, our Moon and the planets in the solar system. To help you get a better solar or lunar image with clear details, ASIAIR allows you to choose the alignment point before stack. And for solar stacking, ASIAIR also supports colorization for mono image and color invert.
Basically, the stacking process for planetary videos is similar to DSO stacking. One of the few differences is that the histogram can only be viewed but not stretched in edit.
Choose the video you’re going to stack.
Choose the planetary target to stack
Stacking.
Saturn stacking
Sharpen the image or do other image adjustments.
planetary stacking - sharpen
Share it to the community or save the image.
planetary stacking -share
Really simple, right? With the new 2.0 version of ASIAIR, you now can complete the whole capture and process workflow on your phone. Astrophotography can be fun for every amateur, no matter you are a master or just a newbie.
前の投稿 次の投稿
コメントを残す
コメントは公開する前に承認されなければなりません
