Wide field imaging with ASI cooled cameras and LighTrack II mount
If you are looking for the mount that is small, flexible, quick to assemble, portable and enough precise for wide field photography with lens for trips under the dark sky, here is an article about it. The LighTrack II, a portable mount was made by FORNAX, a Hungarian company who is also running a very successful science project HATNet (hatnet.org). The LighTrack II is the first portable mount with friction drive on the market. The friction strip makes the movement of the mount very balanced and enables high tracking accuracy. FORNAX guarantee tracking error of the LighTrack II less than 2 arcseconds in eight minutes measuring and much more. The LighTrack II is also very interesting due to compact size and light weight (1.3 kg or 2.9 lbs). That characteristics seems to be an ideal choice for portable tracking mount.
We tested the LighTrack II with 135-mm f2.8 lens and ASI cameras, mono ASI1600 + filter wheel and color ASI071. The maximum recommended payload for this mount is 6 kilograms. Assembling the LighTrack II on a tripod is pretty quick and easy. The LighTrack II runs on 12V DC and comes with a cigarette lighter charger cable that can be connected to a power bank (a small power bank with 7 Ah is more than enough). We also tested FMW-200 wedge with polar finder scope which was designed for the LighTrack II. Polar alignment with it has never been easier. FMW-200 wedge is made from a massive aluminum body and is very precise and enables very precise movements in both ways - altitude and azimuth.
fornax-lightrackII-ASI071
The LighTrack II mount is very suitable for imaging with our ASI cooled cameras any type of photo lenses up to 300-mm focal length. The imaging process is very simple and fast. We have to assemble the LighTrack II, ASI cooled camera and all other necessary parts, and then we just point out on a target and start capturing. Very simple! At the moment we run ASI cooled camera under computer control, but very soon you will need only LighTrack II mount, ASI cooled camera, PowerTank and instead of computer our brand new ANDROID application. All these features will bring astrophotography to the next level!
As we know dithering is necessary for astrophotography when we use ASI cooled CMOS cameras. When using a guided telescope mount and CMOS camera we got noise pattern (image bellow) on our final stack image. Most guiding softwares support dithering and simply displace the image for a set amount of pixels by displacing the guiding star after every exposure (for example PHD). In the case of LighTrack II mount with photo lens dithering is not necessary. Why? LighTrack II mount without precise guiding cannot track such precisely like guided mount, FORNAX52 for example. Every captured frame with LighTrack II is slightly different and eliminate this problem very well (every image is a little bit shifted on the sensor). When we stack all our images in one final image stacking process will eliminate this noise pattern very well. But this does not mean that the mount is not precise! With LighTrack II and good polar alignment with 135-mm lens we can do also 400-seconds exposure (the recommended longest exposure duration from FORNAX is 360 seconds or 6 minutes)!
dithering-optimal-results-cmos-strophotography Noise pattern on finale stack image. Images was captured with 20-cm telescope, ASI1600 and OAG.
And the final result? During the winter we were imaging Orion Nebula (also known as Messier 42, M42, or NGC 1976) a diffuse nebula situated in the Milky Way with LighTrack II, 135-mm f2.8 lens, and our ASI071 cooled camera (subexposure time was 200-sec ). Final result is outstanding!
fornax-lightrackII-ASI071-OrionNebula
Lascia un commento
