3 Steps to Find Deep Space Objects with ASIAIR
The target searching features of ASIAIR are very powerful and easy to use. No need to switch to another software to find the star anymore. Since ASIAIR’s 1.0.7 version, you just need to take 3 simple steps to find your target. First, you need to click Choose Object, then select your imaging target tonight. 1 Confirm your target. We can start now! Step one: Press GOTO. The equatorial mount will automatically rotate and eventually point towards the target. 2 Step two: Take a photo and Plate Solve it. The software will automatically calculate the current RA and Dec value. Press Sync Mount to synchronize the data to the equatorial mount. 3 Step three: Choose GoTo again to let the mount correct the deviation. 4 Done. The target is in the center of your FOV. You can formally start photography now. Easy, right? 5
ASIAIR makes astrophotography so easy.
Laisser un commentaire
