  • 🔥Black Friday Sale
  2. Black Friday
  3. Ha Filters
  1. Previous
  2. Next
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
$127.00 Regular price $149.00
Narrowband filter does not eliminate the effects of light pollution or increase the object’s brightness. In many cases, they increase the contrast between the nebula and the night sky, not brightening the nebula.
It can reduce the transmission of certain wavelengths of light, specifically, those produced by artificial light including mercury vapor, and both high and low-pressure sodium vapor lights and the unwanted natural light caused by neutral oxygen emission in our atmosphere (i.e. skyglow).
From 2018, ZWO Made progress on narrowband filters with the new standard, providing better performance.
The ZWO H-Alpha filter has a bandpass of 7nm and passes light at 656nm wavelength, the light transmission rate comes up to 80%. Best choice of narrowband H-alpha astrophotography filter for high-contrast imaging and revealing rich details of the nebula even in areas with strong light pollution, just prepare to experience the infinite fun with it!
New narrowband 1.25″ filter
ZWO New narrowband H-Alpha 1.25\
Technical Parameter
Thickness: 5.5mm+2.5mm(thread)
Glass thickness: 1.85mm
Thread: M28.5*0.6 male thread
We made a test of our Ha Filters (ASI1600 mono camera, single frame, 300s, DDP in MaximDL) :
ZWO H-Alpha filter imaging test result
ZWO New narrowband 31mm filter
Technical Parameter
Thickness: 2mm
ZWO New narrowband H-Alpha 31mm filter product view
ZWO New narrowband 2″ filter
ZWO New narrowband H-Alpha 2\
Technical Parameter
Thickness: 5mm+2.5mm(thread)
Thread: M48*0.75 male thread
ZWO New narrowband 36mm filter
Name: ZWO New narrowband 36mm filter
Thickness: 2mm
ZWO New narrowband H-Alpha 36mm filter product view
  • Hubble look of images can be made by the combination of H-alpha, OIII-CCD and SII-CCD, such as the famous “Pillars of Creation” (M16 Eagle Nebula)
  • Narrowband imaging with SHO set (H-alpha, OIII-CCD and SII-CCD) can be done with the moon up in heavy light pollution, so your equipment is not sitting dormant for several weeks
  • The H-alpha filter is the first narrowband addition to the LRGB set for most imagers who blend a black-and-white Ha image into RGB data to enhance structural detail while maintaining a natural look.
Technical Data
  • FWHM:7±0.5nm
  • Glass Thickness 2.0+/-0.03 mm (31mm/36mm)
  • Fine-optically polished to ensure accurate 1/4 wavefront over the both surfaces
  • About 90% transmission at H-alpha line 656nm (H-Alpha filter )
  • About 90% transmission at SII line 672nm (SII filter )
  • About 90% transmission at major OIII line 500nm (OIII filter )
  • Infrared wavelength 700-1100nm cut-off
  • <0.1% transmission of off-band, OD3(Optical Density)
Transmission Curve
ZWO New narrowband H-Alpha filter transmission curve diagram
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
Ha Filters
$127.00 $149.00
