  • 🔥Black Friday Sale
  2. Black Friday
  3. ASI174MM (mono)
  1. Previous
  2. Next
ASI174MM (mono)
ASI174MM (mono)
ASI174MM (mono)
$539.00 Regular price $599.00
Our popular ASI174MM CMOS Monochrome Imaging Camera is based on the Sony Exmor IMX174 2.35MP sensor with Pregius global shutter technology.
ZWO ASI174MM monochrome imaging camera product shot
ASI174MM camera technical detail close-up
▶Sony IMX174 CMOS Sensor Features
  • The Sony IMX174 monochrome CMOS sensor separates the ASI174MM from previous ASI models. This type 1/1.2” Sony CMOS image sensor features a 1936 x 1216 array with, 5.86µm pixels in it. It has a lot of advantages when taking high-quality solar, lunar, planetary, and deep sky object images.
  • Pregius Global Shutter function with analog memory permits the scanning of all pixels simultaneously. The Sony IMX174’s global shutter function provides improved image quality by making sure images of moving objects avoid focal plane distortion. This is especially helpful when performing solar or lunar imaging. Bad seeing, wind, or movement can alter the image if the readout speed is not quick enough (< 30fps).
  • Sony Exmor technology uses column-parallel A/D conversion for high-speed processing, low noise, and low power dissipation.
  • ROI, or Region of Interest Mode lets you capture up to 16 areas inside the effective pixels. This ability allows for even higher frame rates.
  • High-speed imaging with a max of 164.5 fps at 10-bit ADC, and max of 128.2 fps at 12-bit ADC.
Astrophotography Performance
ASI174MM astrophotography sample image
High QE
Absolute QE Curve, we estimate the Peak Value is about 77%.
ASI174MM Quantum Efficiency (QE) curve graph
USB 3.0 Port & ST4 Port
USB 3.0 Port: can provide 5Gb bandwidth to let ASI174 run at 128 fps (12bit, normal mode) or 164 fps (10bit, high-speed mode) at full resolution(2.35Mega).
ST4 Port: can be used connect with auto guide port of mount, for guiding.
ASI174MM ports close-up (USB 3.0 and ST4)
Back Focus
After remove T2 11mm ring, back focus length will be only 6.5mm.
ASI174MM back focus diagram and measurement
Mechanical Diagram
ASI174MM mechanical structure diagram
Reference Images:
ASI174MM astrophotography reference image 1 (e.g., lunar surface)
ASI174MM astrophotography reference image 2 (e.g., planetary detail)
ASI174MM astrophotography reference image 3 (e.g., solar detail)
ASI174MM astrophotography reference image 4 (e.g., deep sky object)
ASI174MM astrophotography reference image 5 (e.g., star cluster)
ASI174MM astrophotography reference image 6 (e.g., nebula detail)
ZWO ASI camera product display
What is in the box?
Package contents of ASI planetary camera (e.g., camera, cables, adapters)
* The USB 3.0 cable in the ASI planetary camera boxes was changed from black to red since June 2023.
ASI174MM (mono)
ASI174MM (mono)
ASI174MM (mono)
$539.00 $599.00
